TomAgos
- Newbie
Post
by TomAgos » Wed Mar 19, 2025 12:42 pm
Hey
im using the 'Point' series on top of 'FastLine' to show the points in the line.
my question is:
can i make the shape of the Pointer of Points to not fill the inner shape with the color?
this is my code to create instance of Points:
public static Points CreatePointsLine(DataRecVectorM vectorM, Chart chart)
return new Points(chart)
Color = ChartDataToZData.MColorToDColor(vectorM.Color),
Pointer =
Style = vectorM.SelectedSymbolStyle,
HorizSize = 5,
VertSize = 5,
For example, if the defined color is red and the shape (Pointer.Style) is triangle, i want to draw a red triangle but transparent on the inside.
Edu
- Newbie
Post
by Edu » Wed Mar 19, 2025 2:54 pm
Hello TomAgos,
There are a few ways to achieve this. If you're using a WinForms App, you can use the design-time editor to help you explore all the possibilities with ease. However, here’s how you can do it through code.
Given a Point series like this
Points points = new Points();
You can set a red border with a transparent inside using the following line:
points.Pointer.Pen.Color = System.Drawing.Color.FromArgb(255, 0, 0); // Red
To change the pointer shape to a triangle, use:
points.Pointer.Style = Steema.TeeChart.Styles.PointerStyles.Triangle;
Another way to make the inside transparent is by setting the same color for both Points.Color and _TChart.Panel.Color
For example, if you haven’t changed the chart's panel color (which is usually white), you can use:
points.Color = Color.FromArgb(255, 255, 255); // White
I hope these tips were helpful! Let me know if they worked for you, or if we should explore a different approach. If there’s anything else I can assist you with, feel free to ask.
Best regards,
Edu
Edu
