Get MouseOver when mouse is over a mark
Mandi Nice
Post by Mandi Nice » Mon Jul 13, 2009 7:00 pm
How to find out when mouse is over an mark and get information which chart and which data point.
I only show the mark of the series and I want to show an hint when mouse is over an mark.
There should show a sepperate hint for each mark.
many thanks for helping.
Best Regards
Mandi
Re: Get MouseOver when mouse is over a mark
Post by Yeray » Tue Jul 14, 2009 9:30 am
Hi Mandi,
You could do something like in the following example:
uses series, TeeTools;
var series1: TBarSeries;
    annotation1: TAnnotationTool;
  series1 := TBarSeries.Create(self);
  Chart1.AddSeries(series1);
  series1.FillSampleValues(6);
  annotation1 := TAnnotationTool.Create(self);
  Chart1.Tools.Add(annotation1);
  annotation1.Active := false;
  Chart1.Draw;
  Y: Integer);
var i, j: Integer;
    p: TPoint;
    r: TRect;
  p.X := X;
  p.Y := Y;
  for i:=0 to Chart1.SeriesCount-1 do
    for j:=0 to Chart1[i].Count-1 do
      r.Left := Chart1[i].Marks.Positions[j].LeftTop.X;
      r.Top := Chart1[i].Marks.Positions[j].LeftTop.Y;
      r.Right := Chart1[i].Marks.Positions[j].LeftTop.X + Chart1[i].Marks.Positions[j].Width;
      r.Bottom := Chart1[i].Marks.Positions[j].LeftTop.Y + Chart1[i].Marks.Positions[j].Height;
      if PtInRect(r, p) then
        annotation1.Left := r.Right + 5;
        annotation1.Top := r.Top;
        annotation1.Text := 'value number ' + inttostr(j);
        annotation1.Active := True;
        Exit;
      end
        annotation1.Active := False;
