Silverlight Chart resizing
Farsider
Post by Farsider » Wed Jun 17, 2009 7:39 pm
I am unable to get the Silverlight TChart control to resize when the browser resizes. I have tried to set TChart control's HorizontalAlignment and VerticalAlignment to Stretch with no luck. I have attempted to set TChart control's Height and Width when it's containing grid resizes but the change has no effect on the dimensions of the control. What am I doing wrong?
Re: Silverlight Chart resizing
Post by Narcís » Mon Jun 22, 2009 2:24 pm
Hi Farsider,
I'm afraid this is a bug (TW24014257) which I have added to the defect list to be fixed for future releases.
Post by Narcís » Fri Jun 26, 2009 1:58 pm
Hi Farsider,
We have investigated the issue and we are not sure if this is about Teechart.Silverlight.dll or about the use of the Silverlight framework. I attach an example using a standard Silverlight UserControl which exibits exactly the same behaviour as Teechart. Can you please have a look at this project and check if you can get resize to work with the standard SilverLight UserControl?
TeeChartv4Silverlight_2008.zip
(8.58 KiB) Downloaded 364 times
