ColorGridSeries Axis problem
JKLee
Post by JKLee » Sat May 16, 2009 8:00 am
Using
- C++ Builder 2007
- TeeChart Pro 8.04 VCL
When I developed a program with TeeChart Pro 7.x, I have no problem.
but after upgrade teeChart 8.04, occur some problems.
ColorGridSeries problems.
when Axis inverted, colorgrid draw not inverted.
and draw other values in same axis.
Post by Yeray » Mon May 18, 2009 7:58 am
Hi JKLee,
Please, could you send us a simple example project we can run "as-is" to reproduce the problem here?
JKLee
Post by JKLee » Wed May 20, 2009 5:57 am
after run my sample Program.
firstly click the BitBtn1.
you can see the color grid image in X range (0~100).
and check Invert.
so, x axis inverted.
but color grid image draw in x range (0~-100).
correct image draw x range (0~100)
Post by Yeray » Wed May 20, 2009 10:38 am
Hi JKLee,
Yes I've reproduced it with TeeChart v8.04 but TColorGrid series has been highly modified since then and with actual sources I it seems to be ok. So, for the next maintenance release that will be released soon, it should be fixed.
