Sample app for Teechart for Java is not getting compiled
SDG
Post by SDG » Fri May 08, 2009 12:34 pm
I am writing a sample application to test TeeChart for Java and getting following error while compiling demo Java file. Kindly advice me.
cannot access com.steema.teechart.drawing.ChartPen
bad class file: C:\PServer50\server\nodes\fdms_charts\archives\public_html\FDMS\TeeCharts\jars\TeeChart.Swing\com\steema\teechart\drawing\ChartPen.class
class file has wrong version 49.0, should be 48.0
Please remove or make sure it appears in the correct subdirectory of the classpath.
import com.steema.teechart.drawing.ChartPen;
Post by Narcís » Fri May 08, 2009 1:21 pm
Hi D486909,
Which exact TeeChart for Java version are you using? Notice that on last 27th April we posted a new version at the client area.
SDG
Post by SDG » Sat May 09, 2009 8:30 am
Downloaded eval version just a week back.
Post by Marc » Mon May 11, 2009 2:10 pm
Please could you describe a little more about the project setup to help us reproduce the problem. We've been unable to generate the problem using the latest evaluation version and the following steps.
Steps taken:
- new netbeans desktop application
- added TeeChart to the palette and added to form
- added button with following code:
tChart1.getSeries().add(new com.steema.teechart.styles.Line());
tChart1.getSeries(0).fillSampleValues();
tChart1.getAxes().getAxis(0).getAxisPen().setWidth(4);
tChart1.getAxes().getAxis(0).getAxisPen().setColor(java.awt.Color.yellow);
The code runs successfully, modifying the two Pen characteristics of the Axis.
SDG
Post by SDG » Tue May 12, 2009 4:21 am
Hello Marc,
Thanks for the reply. Code is working.
Best,
Veeranna Ronad.
Wheb
Re: Sample app for Teechart for Java is not getting compiled
Post by Wheb » Mon Feb 20, 2012 4:37 pm
I´m using the teechart component within my applications, and i´m experiencing some sort of problems. Maybe the problems are being
caused by my own applications, but the point is, when i choose to resize the application window, the border that i´ve draw on the
line with the command getOutLine().setVisible(true) increase it´s own size. I mean, i really have a default size for this border but when the window is resized, the border simply change it´s size.
Hope that you can help.
Marcel
Post by Yeray » Tue Feb 21, 2012 10:06 am
Hi Marcel,
I'm trying to reproduce it here with the following code in Eclipse, but the line looks the same size after resizing the window.
import org.eclipse.swt.events.ControlEvent;
import org.eclipse.swt.events.ControlListener;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Display;
import org.eclipse.swt.widgets.Shell;
import com.steema.teechart.TChart;
import com.steema.teechart.misc.Utils;
import com.steema.teechart.styles.Line;
public class Test {
	static Display display;
	static Shell shell;
	static TChart tChart1;
	public static void main(String[] args) {
		display = new Display();
		shell = new Shell(display);
		shell.setLayout(new FillLayout());
		shell.setSize(800, 500);
		createChart();
		initializeChart();
		shell.open();
		while (!shell.isDisposed()) {
			if (!display.readAndDispatch()) {
				display.sleep();
		display.dispose();
	private static void createChart() {
		tChart1 = new TChart(shell, 0);
	private static void initializeChart() {
		Line line1 = new Line(tChart1.getChart());
		line1.fillSampleValues();
		line1.getOutLine().setVisible(true);
		shell.addControlListener(new ControlListener() {
            @Override
            public void controlResized(ControlEvent arg0) {
                tChart1.setBounds(Utils.fromLTRB(0, 0, shell.getSize().x, shell.getSize().y));
                tChart1.doInvalidate();
            @Override
            public void controlMoved(ControlEvent arg0) {
Could you please check the code above for you?
