Bar Chart Missing Some Bars
McMClark
Post by McMClark » Tue Apr 28, 2009 11:05 pm
I am using TeeChart 7.12 with Delphi 2006 Studio VCL. I have a form with a DB Chart filled by a NexusDB query. The DBChart shows a bar chart series with dates along the X axis and numerical values from 0 to 5 on the Y axis. I have a tee navigator attached to the chart so that I can page through the points when they total more then 10. On some of the chart pages some of the bars do not appear even though the label for the point appears. I checked the query and the points do have data. Can you suggest what I can check to fix the problem?
Post by Yeray » Wed Apr 29, 2009 11:20 am
Hi McMClark,
We have some similar bugs identified with TeeChart v8 (and some of them are already fixed) but I'm not sure to identify what is your exact problem.
Here is the code I used to try to reproduce it, but I couldn't. Could you please modify it in order to reproduce it? Or could you send us a simple example project we can run "as-is" to reproduce the problem here?
uses series;
var i: Integer;
    series1: TBarSeries;
  ChartPageNavigator1.Chart := Chart1;
  series1 := TBarSeries.Create(self);
  Chart1.AddSeries(series1);
  for i:=0 to 25 do
    series1.Add(random*5);
  Chart1.MaxPointsPerPage := 10;
McMClark
Post by McMClark » Wed Apr 29, 2009 6:15 pm
Below are there procedures that involve assigning values to the series,
updating the points per page with the user's selection, and getting the first date from the X axis value on the DBChart page.
procedure TfrmDefaultResultGraphAndDocuments.FormShow(Sender: TObject);
//This code adds a series to the dbChart based on a query attached to a datasource
ChartPageNavigator1.Chart := DBChart1;
DBChart1.MaxPointsPerPage := intPointsPerPage;
intList2 := ds1.RecordCount;
with tmpDefaultSeries do
DataSource := ds1;
YValues.ValueSource := strYSource;
XLabelsSource := strXSource;
XValues.ValueSource := strXSource;
try
XValues.DateTime := True;
except
Title := strSubModel + ' ' + strSeriesName;
tmpDefaultSeries.ColorEachPoint := False;
tmpDefaultSeries.Marks.Visible := True;
tmpDefaultSeries.Marks.Style := smsValue;
DBChart1.Draw;
procedure TfrmDefaultResultGraphAndDocuments.UpdatePointsPerPage(var DBChart1: TDBChart; blRestrictPoints: Boolean; var intMaxPointsPerPage2: integer; intDefaultMaxPointPerPage: Integer);
//This code updates the points per dbChart page based on the user selection
if blRestrictPoints then
if intMaxPointsPerPage2 = 0 then
intMaxPointsPerPage2 := intDefaultMaxPointPerPage;
DBChart1.MaxPointsPerPage := intMaxPointsPerPage2;
end
intMaxPointsPerPage2 := 0;
procedure TfrmDefaultResultGraphAndDocuments.ChartPageNavigator1ButtonClicked(
Index: TTeeNavigateBtn);
strXVar: String;
dbXVar: Double;
Sender2: TChartSeries;
intPage: integer;
dtAnalysisDate1: TDate;
intPointsPerPage: integer;
//This code gets the first date on the page to use to synch up information about that //date
DBChart1.Axes.Reset;
try
Sender2 := DBChart1.Series[0];
intPage := DBChart1.Page;
intPointsPerPage := DBChart1.MaxPointsPerPage;
if intPage = 1 then
strXVar := Sender2.XValueToText(Sender2.XValue[0])
end
strXVar := Sender2.XValueToText(Sender2.XValue[((intPage -1) * intPointsPerPage)]);
try
dtAnalysisDate1 := strToDate(strXVar);
except
except
Post by Yeray » Thu Apr 30, 2009 9:35 am
Hi McMClark,
There are many things I cannot use only with this code (datasource, UpdatePointsPerPage). Here is how I simplified it in order to be runnable as-is:
  Series1.FillSampleValues(100);
  Chart1.MaxPointsPerPage := 5;
  with Series1 do
  Chart1.Draw;
procedure TForm1.ChartPageNavigator1ButtonClicked(Index: TTeeNavigateBtn);
  strXVar: String;
  intPage: integer;
  Chart1.Axes.Reset;
  try
    Sender2 := Chart1.Series[0];
    intPage := Chart1.Page;
    intPointsPerPage := Chart1.MaxPointsPerPage;
    if intPage = 1 then
  except
  Caption:= strXVar;
But I'm afraid that with this I still can't reproduce the issue. Please, try to modify it until the problem will be reproducible as-is or send us a simple example project we can run as-is here.
McMClark
Post by McMClark » Tue Jun 02, 2009 7:37 pm
Thank you for the reply. I am still working on producing a reproducible example of the error. But I wanted to let you know that the missing bars reappear when I turn off the 3D display. If I toggle the 3D button on the tee commander, the appears and disappears.
