Text missing and solutions
THoMaSiN
Post by THoMaSiN » Thu Apr 02, 2009 11:07 pm
Hello, I have generated a bar chart that plots as in the uploaded image file: example.bmp
The problem is that the labels are missing.
The solution might be to plot the bars horizontally instead of vertically, with the lables on the left side and the amount in the bottom, how can I achieve that?
thank you !!
Post by Yeray » Fri Apr 03, 2009 10:37 am
Hi THoMaSiN,
You could set an angle like following:
But note that with labels rotated you may see less labels than you would like to. If so, please, take a look at this thread where Narcís posted a workaround.
