Line Series in TeeChart v2
Jesse
Post by Jesse » Fri Mar 20, 2009 5:11 pm
After upgrading, I discovered different behavior. It is easy to accomodate, so I am not requesting any action. Anyway, FYI in case it wasn't expected.
When you set the color of a line series with point markers, subsequent changes to the color only affect the line and not the pointer.
import javax.swing.JFrame;
import javax.swing.JPanel;
import com.steema.teechart.TChart;
import com.steema.teechart.drawing.Color;
import com.steema.teechart.styles.Histogram;
import com.steema.teechart.styles.Line;
import com.steema.teechart.styles.PointerStyle;
public class ChartTest {
	public static void main(String[] args) throws InterruptedException {
		line();
	private static void line() throws InterruptedException{
		JFrame frame = new JFrame();
		ChartTest c = new ChartTest();
		JPanel panel = new JPanel();
		TChart chart = new TChart();
		panel.add(chart);
		frame.add(panel);
		final Line l = new Line();
		l.add(1,10);
		l.add(2,20);
		l.add(3,5);
		l.add(4,25);
		l.add(5,15);
		l.setColor(Color.GREEN);
		l.getPointer().setStyle(PointerStyle.DIAMOND);
		l.getPointer().setVisible(true);
		l.setChart(chart.getChart());
		chart.getAspect().setView3D(false);
		chart.getAspect().setSmoothingMode(false);
		frame.pack();
		frame.setVisible(true);
		frame.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
		//wait a second
		Thread.sleep(1000);
		l.setColor(Color.BLUE);
		//without the following line, the point markers will remain the same as before
		l.getPointer().setColor(Color.BLUE);
Post by Yeray » Mon Mar 23, 2009 9:21 am
Hi Jesse,
We've tried to reproduce this issue but couldn't with the actual sources nor with v2 installer.
Are you sure that you haven't skipped to mention any important step?
