Scatter graph and Trend line
VGrillot
Post by VGrillot » Wed Mar 04, 2009 4:34 pm
I'm trying the TTrendFunction with a scatter graph.
In this graph there is a compact cloud, and few lost points, most on the right.
Here a screenshot if I add a trend line:
It's obvious that the trend line is false. At least the trend line is not what could be expected.
Is there a tool somewhere in steema library to automatically detect cloud, and ignore losts points ?
Here the result if I remove "manually" losts points, and add a new trend line (in green):
Thanks for any help,
Vincent.
Post by Yeray » Thu Mar 05, 2009 2:48 pm
Hi Vincent,
Yes, it seems that points far of the core are more significant for the function than the others.
As you say, one workaround could be setting a condition to filter the "distant points" but I'm afraid I can't think on a general solution right now. I recommend you, if possible, to do your custom filter knowing the characteristics of your series.
You could create a dummy points series inactive, copy the validated points from the original one to it, and assign the trend function to this filtered series.
