Series Points
nbp
Series Points
Post by nbp » Fri Feb 20, 2009 10:18 pm
I need to display the Line Series point on the chart via my code. How do I set the visibility to true? What property of TChartSeries do I use?
I need to implement the same functionality as that in the TChart Editor, Series Tab, Point Tab, Visible check.
Post by Yeray » Mon Feb 23, 2009 10:49 am
Hi nbp,
Yes, you should do somethink like this:
TChart1.Series(0).asLine.Pointer.Visible = True
