Specific Spline X value required at Y Maximum
swesty
Post by swesty » Wed Feb 18, 2009 5:38 am
Hi Steema,
I have just purchased the latest VCL Pro version and have implemented a Spline function which works perfectly. My next requirement is to get a specific X value from the Y Maximum of the spline. Is this possible and if so how do I achieve this ?
Steve West
Post by Yeray » Wed Feb 18, 2009 11:05 am
Hi Steve,
Here is how you could search for your function maximum:
var maxY: double;
maxYIndex, i: integer;
  maxY := Series2.MaxYValue;
  for i:=0 to Series2.Count-1 do
    if (Series2.YValue[i] = maxY) then
      maxYIndex := i;
      break;
  caption := 'maxY: ' + floattostr(maxY) + '  maxYIndex: ' + inttostr(maxYIndex) + '  X: ' + floattostr(Series2.XValue[maxYIndex]);
swesty
Post by swesty » Wed Feb 18, 2009 11:46 am
Yeray,
Thanks for the reply. I should have included a little more information on how I use the spline function. I have tried the method shown in your reply but I have had no luck as the TSmoothingFunction gives me no data in my series. Here is what I have so far.......
unit testofspline ;
// procedure declarations here
SplineFunction : TSmoothingFunction ;
SplineSeries : Array[1..10] of TLineSeries ;
MDRPointSeries : Array[1..10] of TPointSeries ;
XatYPeak,YPeak : Real ;
procedure TTestofSplineForm.CalculateandDrawSpline(LabNoIndex) ;
i : integer ;
MDRPointSeries[LabNoIndex] := TPointSeries.Create(Self) ;
SplineFunction := TSmoothingFunction.Create(self) ;
SplineFunction.Interpolate := true ;
SplineFunction.Factor := 8 ;
SplineSeries[LabNoIndex] := TLineSeries.Create(Self) ;
SplineSeries[LabNoIndex].SetFunction(Splinefunction) ;
MDRPointSeries.AddXY(5.5,1.85,'',clTeal) ;
MDRPointSeries.AddXY(6.5,1.90,'',clTeal) ;
MDRPointSeries.AddXY(7.5,1.95,'',clTeal) ;
MDRPointSeries.AddXY(8.5,1.91,'',clTeal) ;
SplineSeries[LabNoIndex].DataSource := MDRPointSeries[LabnoIndex] ;
SplineSeries[LabnoIndex].checkDataSource ;
YPeak := SplineSeries[LabNoIndex].MaxYValue ;
for i := 0 to SplineSeries[LabNoIndex].Count-1 do
if SplineSeries[LabNoIndex].YValues = YPeak then
XatYPeak := SplineSeries[LabNoIndex].XValue ;
Using this code above I end up with nothing that is accessible as points in my SplineSeries which is odd because the line is drawn perfectly on the graph. What am I doing wrong ?
swesty
Post by swesty » Wed Feb 18, 2009 11:49 am
The lines shown as
should read
MDRPointSeries[LabNoIndex].AddXY(5.5,1.85,'',clTeal) ;
MDRPointSeries[LabNoIndex].AddXY(6.5,1.90,'',clTeal) ;
MDRPointSeries[LabNoIndex].AddXY(7.5,1.95,'',clTeal) ;
MDRPointSeries[LabNoIndex].AddXY(8.5,1.91,'',clTeal) ;
sorry about that was hashing code from my main project into a unit.
Steve
Post by Narcís » Wed Feb 18, 2009 2:18 pm
Hi Steve,
Could you please send us a simple example project we can run "as-is" to reproduce the problem here ?
swesty
Post by swesty » Wed Feb 18, 2009 10:19 pm
Hi Narcís,
I have uploaded an app as requested. Very basic but does do what I have tried to explain in this post so far. The file I have uploaded is called TestofSplineExampleApp.zip
Cheers,
Steve
swesty
I should mention I uploaded via the upload page.
Steve
Post by Yeray » Thu Feb 19, 2009 11:38 am
Hi Steve,
Simply changing the order of some calls, your code works fine for me:
procedure TForm1.CalculateandDrawSpline(LabNoIndex : integer) ;
i : integer ;
  ebYPeak.Text := '' ;
  ebXatYPeak.Text := '' ;
  ebSeriesPointCount.Text := '' ;
  ebPointSeriesPointCount.Text := '' ;
  Chart1.AddSeries(MDRPointSeries[LabNoindex]) ;
  Chart1.AddSeries(SplineSeries[LabNoindex]) ;
    if SplineSeries[LabNoIndex].YValues[i] = YPeak then
    XatYPeak := SplineSeries[LabNoIndex].XValue[i] ;
  ebSeriesPointCount.Text := inttostr(SplineSeries[LabNoIndex].Count) ;
  ebYPeak.Text := FloattoStrF(YPeak,ffFixed,6,3) ;
  ebXatYPeak.Text := FloattoStrF(XatYPeak,ffFixed,4,1) ;
  ebPointSeriesPointCount.Text := inttostr(MDRPointSeries[LabNoIndex].Count) ;
swesty
Post by swesty » Thu Feb 19, 2009 11:53 am
Yeray,
Thanks for that. Perfect. Works fine now.
One thing though, I have used Delphi since Delphi 1 and your standard components as part of Delphi since I can't remember but I have never put my AddSeries before I have processed the points into the actual series. Is this standard practice ? I am sure I read examples over the years showing the AddSeries as almost the last thing to do. Doesn't matter a great deal but I am glad it works. I appreciate the speedy replies from the Steema team.
Kind Regards,
Steve
Post by Yeray » Thu Feb 19, 2009 3:53 pm
Hi Steve,
Well, as you know, when you add a series in design time, the series is created and added to the chart immediately. Then, it's more logic doing one thing just after the other also at runtime but, anyway, I'm glad to see that those examples worked at you end. :)
