ChartPreviewer1.Execute 'operation not supported on printer'
dunion
Post by dunion » Tue Feb 17, 2009 6:31 pm
but ChartPreview(self,myChart) works fine.
using TChartPreviewer seems to treat the (network) printer differently. Anything else to set?
dunion
When printing I also get 'printer selection is not valid'
Post by dunion » Tue Feb 17, 2009 6:59 pm
When printing I also get 'printer selection is not valid' - the previewer looks 'ok'.
Post by Narcís » Wed Feb 18, 2009 2:02 pm
Hi dunion,
This works fine for me here using TeeChart Pro v8.04 VCL with a network printer. Could you please send us a simple example project we can run "as-is" to reproduce the problem here and let us know the TeeChart version you are using?
dunion
For this project I'm on 7.12
Post by dunion » Wed Feb 18, 2009 3:10 pm
I have the latest copy but the current project hasn't been converted to Delphi 2009, so it's on Delphi 2006 and TeeChart 7.12. Does this not work with that version?
Post by Narcís » Wed Feb 18, 2009 3:18 pm
Hi dunion,
This also works fine for me here with Delphi 2005 and v7.12. Could you please send us a simple example project we can run "as-is" to reproduce the issue here?
dunion
I will create a sample as soon as time allows, thanks.
Post by dunion » Thu Feb 19, 2009 11:23 pm
FYI I'm on Vista64 sp1 in case it matters, the build is with Delphi 2006.
I have two charts, at any one time one is visible.
Post by Yeray » Tue Feb 24, 2009 10:09 am
Hi dunion,
I've tested the issue in a Win Vista 64 machine with BDS 2006 and TeeChart Pro 7.12 and I could execute Chart1.Execute and I could print the chart through a network printer without problems.
Please, could you send us a simple example project we can run "as-is" to reproduce the problem here?
