Bug in Anit-Alias tool when using pie chart in 2D mode
marder
Post by marder » Thu Feb 05, 2009 12:29 pm
Hi.
When I use the anti-alias tool in my pie chart a switch to 2D mode, the chart is looking strange:
The borders of the slice do not match correctly.
Im using TeeChart V8.04.
Is this a know issue?
Is there a workaround or when will this be fixed?
Thanks!
Post by Yeray » Thu Feb 05, 2009 2:42 pm
Hi marder,
Yes you are right. I've added it to the wish list to be fixed as soon as possible (TV52013843).
In the meanwhile, you could use this as workaround:
  Chart1.View3D := true;
  Chart1.Aspect.Elevation := 0;
marder
Post by marder » Thu Feb 05, 2009 2:54 pm
Hi Yeray.
Ok, this workaround works fine.
Just like it should look like in 2D mode :wink:
Thanks!
marder
Re: Bug in Anit-Alias tool when using pie chart in 2D mode
Post by marder » Fri Nov 11, 2011 10:50 am
Hi.
I just updated to TeeChart Pro V2011 and noticed that this issue is still not fixed.
Even worse is, that the workaround you offered (whish worked perfectly with TeeChart Pro V8) dose no longer work
The chart looks like this with TeeChart Pro V8:
When I remove the workaround and set just 3DView to False, I still see the issue that I initially reported in this ticket:
Could you please tell me why my initial reported issue has not been fixed in the last 2 years?
Also, could you provide me a workaround that I should use in TreeChart Pro V2011?
Thanks and best regards.
Post by Yeray » Mon Nov 14, 2011 3:09 pm
Hello marder,
marder wrote:Could you please tell me why my initial reported issue has not been fixed in the last 2 years?
When we or our customers detect a bug, we add it into a list assigning a priority to it. One of the things that help us to decide what priority to assign to an issue uses to be if there is a workaround that helps the customer to achieve what's desired. But there are other variables affecting the time to close an item in that list such as the complexity of the problem, the study of the possible collateral damages, the number of issues with even higher priority that claims our team attention,...
marder wrote:Also, could you provide me a workaround that I should use in TreeChart Pro V2011?
I've seen setting Chart3DPercent to 1 makes the initial workaround work again:
  Chart1.Aspect.Elevation:=0;
  Chart1.Chart3DPercent:=1;
However, it's a quite ugly workaround. Another possibility you may prefer, is to use GDI+ instead of the Antialias tool. GDI+ incorporates the Antialias and doesn't reproduce the bug.
uses TeeGDIPlus, Series;
  Chart1.Canvas:=TGDIPlusCanvas.Create;
  Chart1.View3D:=false;
  Chart1.AddSeries(TPieSeries).FillSampleValues();
Anyway, I've incremented the bug priority.
marder
Post by marder » Mon Nov 14, 2011 4:58 pm
Hello Yeray.
Thanks for your fast reply!
The workaround with Chart1.Chart3DPercent := 1dose not work very good.
Both, 3D and 2D charts do not look as smoothly as with TeeChart Pro V8.
Anyway, your other suggestion to us GDI+ canvas work quite well.
Best regards.
marder
Post by marder » Tue Nov 15, 2011 12:01 pm
Hello Yeray.
I encountered 2 other issues when using your suggested workaround with GDI+
1. The background shadow of the chart title is not correctly shown.
This issue does not occur without the suggested workaround.
2. The back-wall of the grey slice is shown/painted over the green slice.
This issue seems to occur even without the suggested workaround. (Should I open a new post for this?)
Are these known issues?
Is there a workaround/fix for these issues?
Post by Yeray » Wed Nov 16, 2011 12:09 pm
Hello marder,
marder wrote:1. The background shadow of the chart title is not correctly shown.
I'm trying to reproduce it with the following code but I can't.
uses TeeGDIPlus;
  Chart1.Title.Transparent:=false;
Could you please modify the code above so we can reproduce the problem here in a simple application?
marder wrote:2. The back-wall of the grey slice is shown/painted over the green slice.
I'm afraid this is a known problem [TV52013467]. It's not a trivial problem that would probably need a complete redesign of the series to be fixed.
marder
Post by marder » Wed Nov 16, 2011 2:29 pm
Hello Yeray.
Related to 1.
Add the following line in order to reproduce this issue:
Chart1.Title.Shadow.Transparency := 0;
Anyway, this is no critical issue. I set my shadow transparency to different value to fix this.
Related to 2.
I cannot reproduce this issue with my former version (TeeChart Pro V8). This is really annoying, since we want to update to Delphi XE2 and therefor need the V2011 of TeeChart.
Could you please tell me when this issue occurs, since it seems to be not always reproducible (seems to be related to the number of slice, their size and the rotation of the chart).
Best regards.
Post by Yeray » Wed Nov 16, 2011 4:04 pm
Hello Marder,
marder wrote:Related to 1.
I haven't still been able to reproduce it here with the code below:
uses TeeGDIPlus;
  Chart1.Title.Shadow.Transparency:=0;
Note in XE you'll have to add "VCLTee.TeeGDIPlus" instead of just "TeeGDIPlus". But I can't reproduce it neither in D7 or DXE2.
marder wrote:Related to 2.
It's not easy to determine the exact conditions where this happens. As you said it depends on many factors. Doing some tests I think we can say that this seems to happen when a slice is drawn from an angle between 0º and 90º, and to an angle equal to 180º or equal to 360º.
marder
Post by marder » Fri Nov 18, 2011 1:14 pm
Hi Yeray.
I have seen this behavior with Delphi 2010 (latest version).
I had the Title.Shadow.Transparency := 0 set in the DFM file itself not in source code, but I don't think that this matters.
Maybe this is related to some other settings of Title.Shadow, however setting the transparency to any other value than 0 resolves this issue.
Ok. I will now just leave this as it and hope that there is not too much complains about this :wink:
Could you please post if there are any news related to this issue (workaround or fix)?
best regards.
marder
Post by marder » Fri Nov 18, 2011 3:33 pm
Dear Yeray.
Sorry, to bother you again, but when using your workaround with "TGDIPlusCanvas.Create()" in my FormCreate event I get an access violation when using this in Delphi XE2 with the pre-release source code edition (from October 04, 2011)
Call stack:
|Address |Module               |Unit                  |Class                   |Procedure/Method       |Line     |
|Running Thread: ID=6816; Priority=0; Class=; [Main]                                                             |
|009E0BCA|SpaceObServer_XE2.exe|SearchData.pas        |                        |FilePropertyToViewType |1722[17] |
|00A9525A|SpaceObServer_XE2.exe|GDIPOBJ.pas           |TGPPen                  |Create                 |2999[0]  |
|00A1F871|SpaceObServer_XE2.exe|TeCanvas.pas          |TCanvas3D               |Create                 |5131[1]  |
|00A9524C|SpaceObServer_XE2.exe|GDIPOBJ.pas           |TGPPen                  |Create                 |2999[0]  |
|00C29DD9|SpaceObServer_XE2.exe|TeeGDIPlus.pas        |TGDIPlusCanvas          |Create                 |295[20]  |
|00C29D98|SpaceObServer_XE2.exe|TeeGDIPlus.pas        |TGDIPlusCanvas          |Create                 |275[0]   |
|00C3EBD2|SpaceObServer_XE2.exe|Main.pas              |TMainForm               |FormCreate             |2005[5]  |
This does not occur when I use the binary version of the XE2 prerelease (November 02, 2011)
best regards.
Post by Yeray » Mon Nov 21, 2011 2:40 pm
Hello Marder,
marder wrote:Sorry, to bother you again, but when using your workaround with "TGDIPlusCanvas.Create()" in my FormCreate event I get an access violation when using this in Delphi XE2 with the pre-release source code edition (from October 04, 2011)
Please, give a try to the final v2011.04 release. If you still have this problem, don't hesitate to let us know.
marder
Post by marder » Mon Nov 21, 2011 4:05 pm
Hello Yeray.
Thanks for inform my about the official release!
I'm afraid, but the exception still occurs with the official release (source code edition) for Delphi XE2 Update 2.
Call Stack Information:
|Running Thread: ID=4572; Priority=0; Class=; [Main]                                                             |
|0095B6A2|SpaceObServer_XE2.exe|SearchData.pas        |                        |FilePropertyToViewType |1722[17] |
|00A09892|SpaceObServer_XE2.exe|GDIPOBJ.pas           |TGPPen                  |Create                 |2999[0]  |
|00998ADD|SpaceObServer_XE2.exe|TeCanvas.pas          |TCanvas3D               |Create                 |5181[1]  |
|00A09884|SpaceObServer_XE2.exe|GDIPOBJ.pas           |TGPPen                  |Create                 |2999[0]  |
|00B8D1A1|SpaceObServer_XE2.exe|TeeGDIPlus.pas        |TGDIPlusCanvas          |Create                 |317[20]  |
|00B8D160|SpaceObServer_XE2.exe|TeeGDIPlus.pas        |TGDIPlusCanvas          |Create                 |297[0]   |
|00BA292E|SpaceObServer_XE2.exe|Main.pas              |TMainForm               |FormCreate             |2006[5]  |
(There are some differences in the lines of the call stack now, so I posted it again.)
Please note that this does not occur for Delphi 2010, using the same source.
Best regards.
Post by Narcís » Tue Nov 22, 2011 10:15 am
Hi marder,
Can you please attach a simple example project we can run "as-is" to reproduce the problem here?
