Export chart to image is not clear
Oblicore
Post by Oblicore » Sun Feb 01, 2009 12:30 pm
Export chart to image is not clear.
Please review the uploaded file "ExportReportTo image.JPG".
Once export to imgae (jpg), the resolution seems to be changed and not as displayed in the UI.
Thanks you for your input.
Wissam[/quote][/url]
Post by Narcís » Mon Feb 02, 2009 11:42 am
Hi Wissam,
Have you tried setting image's dimensions before exporting?
    TChart1.Export.asJPEG.Width = TChart1.Width
    TChart1.Export.asJPEG.Height = TChart1.Height
If this doesn't help please send us a simple example project we can run "as-is" to reproduce the problem here and let us know the TeeChart version you are using.
Oblicore
I have added a zip file called : Studio_tee.zip
Post by Oblicore » Wed Feb 18, 2009 1:21 pm
Back to the same case with the resolution.
The zip file includes a small project that allow to load a teechart file. Here are instructions to see the problem.
1. Load the project and run it.
2. Load teechart
3. Open properties page
4. Go to save and save the teechart with size 600x400
Wissam
Oblicore
Post by Yeray » Wed Feb 18, 2009 2:56 pm
Hi Wissam,
Forcing the size to be 600x400 the result image is this and has 96ppp of resolution:
And leaving the default size (760x415) this is the result again with 96 ppp:
We are not sure to understand the problem you have. We only see a size difference between the two images.
