ColorGrid SeriesMouseListener
McMClark
Post by McMClark » Mon Oct 13, 2008 2:48 pm
I'm trying to receive click events when a user clicks on my color grid. I need to know where in the grid the click occurred so that I can display details relating to that cell. I've added a SeriesMouseListener and a ChartMouseListener, neither of which seems fire at any time. What steps do i need to take to receive those click events?
Thank you
Post by Narcís » Mon Oct 13, 2008 3:06 pm
Hi McMClark,
Thanks for reporting. I could reproduce the issue here and added it (TJ71013450) to the defect list to be fixed for next releases.
McMClark
Post by McMClark » Tue Oct 14, 2008 12:00 pm
narcis wrote:Hi McMClark,
Thank You. Any information on when a fix will go out for this? We're dependent on the colorgrid for an upcoming project and will have to find another solution if a fix isn't made soon.
Post by Marc » Wed Oct 15, 2008 11:20 am
Re. Maintenance release
We will announce it shortly
To resolve the SeriesClick problem, if you are compiling from TeeChart code you can add the following method to the ColorGrid class (com\steema\teechart\styles\ColorGrid.java):
public int clicked(int X, int Y)
  int i, tmpResult = -1;
  double tmpDecAmount;
  int Result = -1;
  int zIndex = -1;
  double XPos = super.getHorizAxis().calcPosPoint(X);
  double YPos = super.getVertAxis().calcPosPoint(Y);
  if (this.centered)
    tmpDecAmount = 0.5;
    tmpDecAmount = 0.0;
  if (!this.getIrregularGrid())
    double YDif = (YPos + tmpDecAmount) - this.getZValues().getMinimum();
    if (YDif >= 0f)
      i = (int)(YDif);
      i = -1;
    if ((i >= 0) && (i < this.getNumZValues()))
      zIndex = i;
    if (zIndex != -1)
      double XDif = (XPos + tmpDecAmount) - this.getXValues().getMinimum();
      if (XDif >= 0f)
        i = (int)(XDif);
        i = -1;
      if ((i >= 0) && (i < this.getNumXValues()))
        tmpResult = this.getIndex(i + 1, zIndex + 1);
    return tmpResult;
  if (super.getXValues().getCount() > 0)
    int num = this.getNumZValues() - 1;
    i = 0;
    if (num >= i)
      num++;
      do
        if (((  (this.getZValues().getValue(i) - tmpDecAmount) <= YPos)
                && ((this.getZValues().getValue(i + 1) - tmpDecAmount) > YPos))
                || (((i == (this.getNumZValues() - 1))) && (((this.getZValues().getValue(i) - tmpDecAmount)) >= YPos)))
          zIndex = i;
          break;
        i++;
      while (i != num);
    if (zIndex != -1)
      int num2 = this.getNumXValues() - 1;
      i = 0;
      if (num2 < i)
        return Result;
      num2++;
      do
        if ((((this.getXValues().getValue(i * this.getNumZValues()) - tmpDecAmount) <= XPos)
          && ((this.getXValues().getValue((i + 1) * this.getNumZValues()) - tmpDecAmount) > XPos)) || (((i == (this.getNumXValues() - 1)))
          && (((this.getXValues().getValue(i * this.getNumZValues()) - tmpDecAmount)) >= XPos)))
          return (zIndex + (i * this.getNumZValues()));
        i++;
      while (i != num2);
  return Result;
McMClark
Post by McMClark » Fri Oct 17, 2008 1:23 pm
well, I must be doing something wrong, I still get no click events. Here's my code. I did add the click method to the colorgrid class. I know I'm using the right JAR b/c the new method is callable from the code that references it.
ColorGrid cg = new ColorGrid(tChart1.getChart());
cg.addSeriesMouseListener(new ColorGridMouseAdapter());
class ColorGridMouseAdapter extends SeriesMouseAdapter
@Override
public void seriesClicked(SeriesMouseEvent arg0) {
System.out.println(arg0.getValueIndex());
@Override
public void seriesEntered(SeriesMouseEvent arg0) {
super.seriesEntered(arg0);
@Override
public void seriesExited(SeriesMouseEvent arg0) {
super.seriesExited(arg0);
thanks for your help.
Post by Narcís » Fri Oct 17, 2008 2:16 pm
Hi McMClark,
It works fine for us here using this code:
        ColorGrid colorGrid1 = new ColorGrid(myChart.getChart());
        colorGrid1.fillSampleValues();
        myChart.addMouseListener(new java.awt.event.MouseListener() {
            public void mouseClicked(MouseEvent e) {
                myChartMouseListened(e);
            public void mouseEntered(MouseEvent e) {
            public void mouseExited(MouseEvent e) {
            public void mousePressed(MouseEvent e) {
            public void mouseReleased(MouseEvent e) {
And implementing the event like this:
    private void myChartMouseListened(java.awt.event.MouseEvent e) {
        int index = myChart.getSeries(0).clicked(e.getX(),e.getY());
        myChart.getHeader().setText(String.valueOf(index));
Could you please check if that works for you?
McMClark
Post by McMClark » Sun Oct 19, 2008 3:36 pm
That worked. Thank You for the quick responses.
