Hi there,
I'm using a TIsoSurface Series to write some data to a 3d Tchart.
Is it possible to dynamically change the properties of the TIsoSurface series at runtime, in order to change the colour style of the data on the chart (e.g. with the click of a button) without reinstantiating the chart itself?
Dynamically change series
Hi Monkey,
Yes, you can do as in the example I posted here. You can also typecast series like in the example here.
Hope this helps.
Hope this helps.
