Having just purchased your TeeChart Pro v6 axtive X version Licence No 9080146 I seem to be having a number of problems with it.
1. Every time I attempt to access the help files I get one or other of the following messages
“Cannot find del5vcl.HLP” or “ Cannot find teechartx5,hlp” What have I done wrong????
2. Where can I find a listing of methods?
3. I have been attempting to implement a WaterFall plot with a Z axis of 10 deep. (A FFT Waterfall plot) Using the cursor tool I have tried to access the Z-plane but the cursor control only appears to work in the XY plane. This also seems to be the case for a number of the other tools supplied. Is this correct and if so is it possible to adapt/modify it so that it operates in all three planes. Eg different Z-Plane selected by cursor keys??. E.g I am trying to provide a readout of each point in the waterfall plot using the cursor.
4. In the above each of the graphs has 256 points in the X Plane. I want to scale the X-axis from 0 to 500 but when I do this the graph adds an additional 256 blank points to each graph. How can I scale the graph to achieve the above
5. It would appear that the help address provided by my package is no longer valid so why is tha address still included?
Cheers Roger Meek
Z Planes and use of cursor control
Hi Roger,
This is a known bug in the Help files of the TeeChart Pro v6. It's on our defect list and a fix for it will be considered to inclusion for the next maintenance release.1. Every time I attempt to access the help files I get one or other of the following messages
You can see them in the TeeChart Pro Tutorials and Help files.2. Where can I find a listing of methods?
Yes, you're correct, this is no supported in the existing version. However we've implemented a new "Surface Nearest" tool for the next TeeChart Pro v7.3. I have been attempting to implement a WaterFall plot with a Z axis of 10 deep. (A FFT Waterfall plot) Using the cursor tool I have tried to access the Z-plane but the cursor control only appears to work in the XY plane. This also seems to be the case for a number of the other tools supplied. Is this correct and if so is it possible to adapt/modify it so that it operates in all three planes. Eg different Z-Plane selected by cursor keys??. E.g I am trying to provide a readout of each point in the waterfall plot using the cursor.
You can scale the X axis using the SetMinMax method and setting an increment.4. In the above each of the graphs has 256 points in the X Plane. I want to scale the X-axis from 0 to 500 but when I do this the graph adds an additional 256 blank points to each graph. How can I scale the graph to achieve the above
Where is included ? Most likely we forget to remove it when we change the Support plans..5. It would appear that the help address provided by my package is no longer valid so why is tha address still included?
Pep Jorge
http://support.steema.com
