Legend Series Order
LAL
Legend Series Order
Post by LAL » Wed Aug 20, 2008 4:13 am
I have added my series in a particular order so that they draw correctly, however that isn't the order I'd like them to display in the chart legend.
So is it possible to control the series order in the legend without changing the order of th series themselves?
Post by Yeray » Wed Aug 20, 2008 8:22 am
Hi LVL,
I'm afraid that the feature you doesn't exist. But there are others that you may haven't seen such as OnGetLegendText and OnLegendDrawSymbol events. And also...
You can hide a series to be shown:
TChart1.Series(0).ShowInLegend = False
Or you could simply invert the legend items order:
TChart1.Legend.Inverted = True
Finally, you always could customize your legend at maximum drawing directly to the canvas what you want.
LAL
Post by LAL » Thu Aug 21, 2008 8:46 pm
Yeray,
Thanks for the reply...I actually worked around this using a combination of hiding series from the legend and adding dummy series just for the legend.
Post by Yeray » Fri Aug 22, 2008 8:23 am
Here is a portion of code showing how you could draw a custom legend directly to the canvas. Only to show how you could also do it.
  With TChart1.Canvas
    'legend rect
    .Rectangle TChart1.ChartBounds.Right - 85, 100, TChart1.ChartBounds.Right - 15, 200
    'series 1
    .Brush.Color = TChart1.Series(0).Color
    .Rectangle TChart1.ChartBounds.Right - 80, 107, TChart1.ChartBounds.Right - 70, 117
    .Brush.Color = vbWhite
    .TextOut TChart1.ChartBounds.Right - 65, 105, "Series 1"
    'series 2
  End With
