How to see a circle from each point of view - TPoint3DSeries
ChZiegelt
Post by ChZiegelt » Mon Aug 11, 2008 4:15 pm
I like to see a full circle or a sphere from where ever I look to a 3D Point.
I am using a 3D chart and the rotate tool. The problem now is, if I look from the side, the Circle is like a plane. I only see a line.
Any idea how to get a result like in TeeOpenGL where a complete sphere is rendered ?
Post by Yeray » Tue Aug 12, 2008 7:51 am
Hi ChZiegelt,
Yes, you could achieve it using OpenGL. Pace a TTeeOpenGL into your form and then use the following code:
TeeOpenGL1.TeePanel := Chart1;  //associate the component to your chart
TeeOpenGL1.Active := True;  //activate the component
