I noticed that saving a chart to a file does not save any groups the user creates at runtime. Is there something else you have to do to save groups along with the chart?
SaveChartToFile doesn't save groups
Hi.
Using TeeChart and code bellow bar series stack group are saved and correctly loaded:
Uses TeeStore,
TeeEditPRO; // <--- Registerrs all series classes
Chart1.FreeAllSeries(nil);
Chart1.AddSeries(TBarSeries);
Chart1.Series[0].FillSampleValues(5);
Chart1.Series[1].FillSampleValues(5);
Chart1.Series[2].FillSampleValues(5);
With (Chart1.Series[0] as TBarSeries) do
MultiBar := mbStacked;
StackGroup := 0;
With (Chart1.Series[1] as TBarSeries) do
StackGroup := 0;
With (Chart1.Series[2] as TBarSeries) do
StackGroup := 1;
procedure TForm1.btnSaveClick(Sender: TObject);
SaveChartToFile(Chart1,'d:\temp\result.tee',True); // <--- Include data
procedure TForm1.btnLoadClick(Sender: TObject);
LoadChartFromFile(TCustomChart(Chart1),'d:\temp\result.tee');
Marjan Slatinek,
