jhhd
- Newbie
Post
by jhhd » Tue May 27, 2008 2:49 pm
I had the aim of storing a number of series in a vector of TChartSeries*, and then when reading them out of the vector, checking their type with typeid(). I ran into the following problem, however, and was wondering if you knew of a reason, and or fix:
TChartSeries* p = new TLineSeries(0);
std::string str1 = typeid(*p).name();
std::string str2 = typeid(TLineSeries).name();
// str1 = "TLineSeries"
// str2 = "Series::TLineSeries"
Obviously this is meaning that I can't do
if (typeid(*p) == typeid(TLineSeries) { ... }
Post
by Pep » Mon Jun 02, 2008 10:20 am
have you tried to check the series type by using classid :
__classid(TLineSeries)
Once you know the Series type you can do the cast by using code similar to :
dynamic_cast<TLineSeries*>(Chart1->Series)-> Pointer ->Visible = true;
