Unit not found, System.pas or bin equiv.
Tim
Post by Tim » Wed May 12, 2004 12:18 pm
I am running d7, build 4.4.53 on xp, sp1 and I upgraded to TeeChart 7. I removed teechart 6 then installed 7 and I get this on any new or existing applications I try to build or compile. Can you tell me how to fix and what happened?
thanks
tim
Tim
fixed, install bug??
Post by Tim » Wed May 12, 2004 1:17 pm
the Environment|Library|Library Path had been deleted. In addition the TeeChart Lib path was not added to the environment either but life is good now!
