transpose tool
mpaulson
transpose tool
Post by mpaulson » Tue Apr 08, 2008 8:45 pm
Hi:
I'm trying to use the transpose tool. However, when the function runs, the colors get reset from that which I assigned to (I think), default tchart values, and after some 10 or so datapoints, these colors revert to gray.
Is there any way to keep the colors I assigned when using the transpose tool?
Matt
mpaulson
Post by mpaulson » Tue Apr 08, 2008 8:47 pm
Also, once I transpose (back and forth once), markers start appearing where before there were none. Why?
Matt
mpaulson
Post by mpaulson » Wed Apr 09, 2008 3:20 pm
Hi:
More information: the series names get reset also.
Matt
Post by Yeray » Fri Apr 11, 2008 9:21 am
Hi Matt,
Yes, you are right. I've added the bug to the wish list (TV52012959) to be fixed in further releases.
One thing I've noticed is that you could conserve the color you set before if you set the color to the whole series, not only to the points. Here is the test:
Private Sub Form_Load()
  TChart1.Tools.Add tcTransposeSeries
  TChart1.AddSeries scBar
'  TChart1.Series(0).Color = vbBlue 'uncomment this to save the series color
  TChart1.Series(0).Add 8, "", vbBlue
  TChart1.Series(0).Add 7, "", vbBlue
  TChart1.Series(0).Add 5, "", vbBlue
  TChart1.Series(0).Add 6, "", vbBlue
  TChart1.Tools.Items(0).asTransposeSeries.Transpose
