TeeChart V8 OpenGL vs. DirectX
Werner
Post by Werner » Fri Apr 04, 2008 3:38 pm
I have developed an application with TChart VCL V8 with TSurfaceSeries with
about 1 million datapoints. So the rotate function with vcl version is very slow.
I have added the teeopengl. The speed is good , but there was some bugs in teeopengl (missing clipping, zooming problems)
So my question:
Is directx supported ? And if, DirectX9 or DirectX10 ?
I have seen that TChart AX supports directx, is this available for delphi ?
How is the speed of TChart AX compare to VCL+OpenGL ?
Has TChart AX the same funtionality as TChart VCL ?
with best regards
Werner
Post by Pep » Sun Apr 13, 2008 9:45 pm
Hi Werner,
No, directx is not supported.
I'm sorry, I'm not sure how you will use the TeeChart ActiveX components with directx, we've not done anything special to support directx on our activeX components.
About Delphi, the TeeChart Pro ActiveX version can be used into the Delphi IDE as standard ocx, but having the specific VCL version available, we do not offer support or this matter.
It should be the same.
Yes, most of the functionalities (features) are the same. You can download and install both and check the demo features project in order to see all functionalities included.
