Creating percentile-lines in histograms, hiding x-markers
Marius
Post by Marius » Thu Feb 28, 2008 11:57 am
Hi. This is a technical detail question:
I have a Histogram, and onto this I want to add some percentile-lines (plines), say 10, 50 and 90. Thus, I am creating 3 thin bars in separate series and adding each series onto the chart in the following manner:
Looping this 3 times:
com.steema.teechart.styles.Bar pLine = new com.steema.teechart.styles.Bar();
            pLine.add(histogram.getMaxYValue());
            va[0] = value;
            pLine.getXValues().value = va;
            pLine.setColor(histogram.getColor());
            pLine.getPoint(0).setLabel(String.valueOf(value));
            pLine.setBarWidthPercent(5);
  pLine.getBrush().setStyle(com.steema.teechart.drawing.HatchStyle.PERCENT90);
            pLine.setShowInLegend(false);
            pLine.setCustomHorizAxis(getHistogramPanel().getXAxis());
            getHistogramPanel().getTChart().getChart().addSeries(pLine);
The problem is that the x-axis of the new series overrides my current. This means that I get only 1 internal gridline on the x-axis, and only one tick on it; displaying the x-value of the latter of the 3 added series.
So, quick question; is there any way I can add a Series whithout displaying its x-axis? Or alternatively, add a series but without affecting the current x-axis?
I try to set the Bars' horizontal axis to the existing one but with no luck.
Also, if there are methods in the API for displaying percentiles which I have overlooked I am grateful for hints on this :)
Thanks a million in advance,
Marius
Post by Narcís » Fri Feb 29, 2008 10:44 am
Hi Marius,
By default all series are set to left and bottom axes as vertical and horizontal axes respectively. So you shouldn't do anything special for that. Anyway you can force this setting:
        tChart.getSeries(0).setHorizontalAxis(HorizontalAxis.BOTTOM);
Anyway, if you want a series custom axis being not visible you can do this:
        tChart.getSeries(0).getCustomHorizAxis().setVisible(false);
I may not understand what you are trying to achieve but I'd use Line series instead of Bar series for drawing the percentile lines.
Hope this helps!
