ModelTech
- Newbie
Post
by ModelTech » Mon Feb 04, 2008 1:54 pm
I want to add to my web chart LegendPalette Tool.
I try to use following code
With Chart8
.Tools.Add(37)
.Tools.Items(0).Active = True
.Tools.Items(0).asLegendPalette.Series = .Series(0)
End With
But it does not work.
What is my mistake?
Thanks in advance,
Danila.
Post
by Narcís » Mon Feb 04, 2008 3:20 pm
Hi Danila,
Code below works fine for me here. Which is the exact problem, tool can't be displayed or it isn't displayed properly? Are you using latest TeeChart Pro v8.0.0.3 ActiveX version available at the client area?
ModelTech
- Newbie
Post
by ModelTech » Tue Feb 05, 2008 7:09 am
I add this tools:
.Tools.Add(37)
there is an empty legend without values
after
At attempt display of page, alert window:
Internet Explorer has encountered a problem witch an add-on and needs to close
TeeChart Pro v8.0.0.2 ActiveX
Windows xp pro IE7,
Windows Server 2003 IE6
Post
by Yeray » Tue Feb 05, 2008 9:12 am
Hi Danila,
Maybe you are trying to use Legend palette with an unaccepted series. Note that this tool only works for 3D series (Surface, Contour, Tower,...)
ModelTech
- Newbie
Post
by ModelTech » Tue Feb 05, 2008 12:57 pm
Contour series is used.
Tools were added with the «Editing» with no errors.
Error occurs while adding this Tools in VBScript.
Thanks in advance,
Danila.
Post
by Narcís » Wed Feb 06, 2008 8:57 am
Hi Danila,
Finally we have been able to reproduce this issue here and added it (TA05012798) to our defect list to be fixed for next releases.
