AV on multipage chart print
GL123
Post by GL123 » Mon Jan 14, 2008 4:03 pm
I'm getting an AV when I attempt to print a multi page chart. My code just calls the ChartPreview function and the AV happens after OK on the select printer dialog.
I tried the feature in the demo app (Tee8New) and it also bombed. Is this a known problem or am I missing something ?
Delphi 7 + Teechart Pro 8.01.10798
Post by Narcís » Mon Jan 14, 2008 4:13 pm
Hi GL123,
Could you please try if including OpenGL unit as described on this thread solves the problem at your end?
If it doesn't, would you be so kind to send us a simple example project we can run "as-is" to reproduce the problem here?
GL123
Post by GL123 » Mon Jan 14, 2008 4:34 pm
Thanks. I tried adding the OpenGL unit but no luck.
I've uploaded a simple test app on the upload page. TeeChartTestApp.zip.
Post by Narcís » Thu Jan 17, 2008 2:05 pm
Hi GL123,
Thanks for the example project. We have been able to reproduce this issue here and added it as a high priority defect in the bug list (TV52012736) to be fixed for next releases.
GL123
Post by GL123 » Thu Jan 17, 2008 3:31 pm
narcis wrote:Hi GL123,
Thanks. Can you suggest any sort of workaround before then? I need to release my software on Monday and this has just been raised as an issue :cry:
xxxxxx
Post by xxxxxx » Sun Jan 20, 2008 11:15 pm
Try draw your charts onto Printer's canvas.
This code draws two charts side by side below the mid of the page
  PX, PY, OrgY, OrgX : Integer;
  R: TRect;
  MetaF : tMetaFile;
  PX:=Printer.PageWidth div 100;
  PY:=Printer.PageHeight div 100;
  OrgX:=PX*8;
  OrgY:=PY*6;
  YourChart1.Printing:=True;
  MetaF:=YourChart1.TeeCreateMetafile(True,Rect(0,0,313,217));
  R:=Rect(OrgX,PY*50,PX*49,PY* 70);
  _Canvas.StretchDraw(R,MetaF);
  MetaF.Free;
  YourChart1.Printing:=False;
  YourChart2.Printing:=True;
  MetaF:=YourChart2.TeeCreateMetafile(True,Rect(0,0,313,217));
  R:=Rect(PX*57,Py*50,PX*98,PY* 70);
  MetaF.Free;
  YourChart2.Printing:=False;
Regards, Alexander
TeeChart Pro v8.05, Delphi 5 & Turbo Delphi Professional for Win32., Delphi & C++Builder 2009
Post by Yeray » Tue Mar 17, 2009 9:37 am
Hi GL123,
We've tested this issue with the actual sources and we aren't able to reproduce this problem. Could you please try if the latest version available to download (v8.04) solves this for you?
