Roll Over Values
Roger
Roll Over Values
Post by Roger » Mon Dec 17, 2007 5:18 am
I'm using Tee chart control on .net application. Whenever I roll over the graph I'm not getting the values since then I'm using IE 7.0 browser. I used to get the values when I rolled over the graphs when I'm using IE 6.0. Please help me,
kiran
Post by Narcís » Mon Dec 17, 2007 9:42 am
Hi kiran,
Could you please send us a simple example project we can run "as-is" to reproduce the problem here and let us know the TeeChart version you are using?
You can post your files at news://www.steema.net/steema.public.attachments newsgroup or at our upload page.
Roger
Roll over values
Post by Roger » Tue Dec 18, 2007 10:46 am
Hi I'm using Teechart 7.0.1.4 version which I have downloaded latestly...I have been trying to view the graphs using IE 7 which is not displaying values when I rollover the values. I have uploaded a application which has the tee chart control and dll which I'm using right now....
File Name is : TeeChart Demo.zip....pls check and let me know....
kiran
Post by Narcís » Tue Dec 18, 2007 11:04 am
Hi kiran,
Thanks for the example project. I've been able to run it here but as far as I can see it is an empty chart with no code at all. Could you please let me know the exact steps I should follow or send a project we can run "as-is" to reproduce the issue here?
Roger
Not found
Post by Roger » Wed Dec 26, 2007 11:34 am
Hi ,
As such I dont have any demo files, as the data is confidential. So if you can check please check the version which I had attached along with the application and reply me whether that teechart version supports displaying mouse over values in IE 7.0 browser...
kiran
Post by Pep » Thu Dec 27, 2007 11:30 am
Hi Kiran,
yes, there's a known problem about using the MarkTips Tool with IE7, in meantime a solution is to use the following code into the script to simulate them :
sub TChart1_OnMouseMove(Shift, X,Y)
    if tchart1.tools.count > 0 then
      tchart1.tools.delete(0)
    end if
    Index = TChart1.Series(0).Clicked(X, Y)
    If Index <> -1 Then
        tchart1.tools.add(10)
	tchart1.Tools.Items(0).asAnnotation.Text = "X: " + CStr(TChart1.Series(0).XValues.Value(Index)) + "Y: " + CStr(TChart1.Series(0).YValues.Value(Index))
        tchart1.Tools.Items(0).asAnnotation.Shape.Left = x
	tchart1.Tools.Items(0).asAnnotation.Shape.Top = Y
    End If
end Sub
Roger
thanks
Post by Roger » Fri Dec 28, 2007 7:06 am
hi pep,
thanks for the reply and also thank you very much for solving my problem....it worked out...
regards
kiran
Roger
Increasing mouse over size
Post by Roger » Wed Jan 02, 2008 11:29 am
the problem is resolved..Can I increase the mouse over div size..As the value is not clearly visible with the existing size
kiran
Post by Narcís » Wed Jan 02, 2008 11:38 am
Hi kiran,
Yes, you can do this:
    TChart1.Tools.Items(0).asAnnotation.Shape.Font.Size = 12
