Strange lines in pie chart
TestAlways
Post by TestAlways » Thu Dec 13, 2007 7:14 pm
v 8.02:
When changing a pie chart from 3-D to 2-D--after playing with the 3d effects (rotation), a strange line appears (see image below, image to the elft of the green slice, above the blue slice)
Post by Yeray » Fri Dec 14, 2007 8:58 am
Hi TestAlways,
I haven't been able to reproduce it here. Please, could you send us a simple example project we can run "as-is" to reproduce the problem here?
TestAlways
Post by TestAlways » Fri Dec 14, 2007 3:21 pm
I've uploaded it.
Note that to create the problem with the demo, simply
1) rotate the pie chart (~30 degrees clockwise),
2) then click on the arrow button in the chart commander and pull the smaller slice out,
3) finally then turn off 3D.
This reproduces the problem every time for me.
Post by Narcís » Fri Dec 14, 2007 3:52 pm
Hi TestAlways,
Thanks for the example project. I've been able to reproduce the issue here and added it (TV52012653) to our defect list to be fixed for future releases.
