Candle - Scrolling, RePaint queries
paligap
Post by paligap » Thu Nov 29, 2007 11:56 am
I am trying to implement TeeCharts for financial charting, i.e. Candle series. Whilst things are progressing OK, I need assistance with the following;
1. I would like the user to be able to scroll (left or right) using a standard VB scrollbar. How can I connect the scrollbar to the teechart so that any scrolling on the scrollbar will result in the chart scrolling in accordance.
2. Zooming, how can I implement a zoom in and out button, keeping in mind the scrollbar will need to adjust also.
3. When setting chart axis through code, am I best to do this in the OnBeforeDrawChart or OnAfterDraw call functions.
4. Can we set the candle width to two decimal places? This would allow the graphical elements (candles) to better grow and shrink as the user zooms in and out.
5. Can I prevent TeeCharts from panning past the data on both the left and right sides of the chart. Scrolling via the mouse is vertical only and I would like to stop TeeCharts from scrolling past the ends of the dataset when using the mouse for scrolling.
6. Can a horizontal line be located between two series. It would be good to be able to position the line using a percent setting just like we can define the heights of series using a percentage range, i.e. StartPosition, EndPosition.
I would really like some feedback on the above, we have implemented some functionality but I would like to know how others have implemented such functionality.
Any help is appreciated.
Cheers
A
Post by Yeray » Fri Nov 30, 2007 3:20 pm
Hi paligap,
I've made an example with a possible a solution for questions 1,2 and 5.
Dim nValues As Integer 'number of values shown from the candle series
Private Sub Command1_Click() 'Zooming
  nValues = nValues - 1
  If nValues > 1 Then
    Command2.Enabled = True
    HScroll1_Change
    With TChart1.Series(0)
      TChart1.Axis.Left.SetMinMax .MinVisibleValue(3) - 5, .MaxVisibleValue(2) + 5
      .asCandle.CandleWidth = .asCandle.CandleWidth + 2
    End With
  Else 'if nValues = 1
    Command1.Enabled = False
    With TChart1.Series(0).XValues
      TChart1.Axis.Bottom.SetMinMax .Value(0) - 0.5, .Value(0) + 0.5
    End With
  End If
Private Sub Command2_Click() 'UnZooming
  If nValues < TChart1.Series(0).Count Then
    Command1.Enabled = True
    nValues = nValues + 1
    If nValues = TChart1.Series(0).Count Then
      Command2.Enabled = False
    End If
    If HScroll1.Value = HScroll1.Max Then 'if we unzoom when showing last value, we have to see another point from the left side
      HScroll1.Value = HScroll1.Value - 1
    Else
      HScroll1_Change
    End If
      If .asCandle.CandleWidth > 2 Then
        .asCandle.CandleWidth = .asCandle.CandleWidth - 2
      End If
    End With
  End If
Private Sub Form_Load()
  TChart1.Zoom.Enable = False
  TChart1.Scroll.Enable = pmNone
  With TChart1
    .Aspect.View3D = False
    .Legend.Visible = False
    nValues = 20
    .AddSeries scCandle
    .Series(0).FillSampleValues 30
    With .Axis.Bottom
      .AutomaticMaximum = False
      .AutomaticMinimum = False
      .SetMinMax TChart1.Series(0).XValues.Value(0), TChart1.Series(0).XValues.Value(nValues - 1)
      .MaximumOffset = 5
      .MinimumOffset = 5
    End With
  End With
  HScroll1.Max = TChart1.Series(0).Count - nValues - 1
  HScroll1.Min = 0
Private Sub HScroll1_Change()
    TChart1.Axis.Bottom.SetMinMax .Value(HScroll1.Value), .Value(HScroll1.Value + nValues - 1)
  End With
Private Sub HScroll1_Scroll()
  HScroll1_Change
Post by Yeray » Mon Dec 03, 2007 9:52 am
Hi paligap,
Note that I've cleaned, explained and improved a little bit the code above right now (Monday 3rd December).
Regarding the other questions:
3. It depends on your axes requests. If you need updated series values to calculate axis settings, you'll need OnAfterDraw event.
4. Note that the property CandleWidth is an Integer, so if you try to set it to, for example, 0.5, the value will be rounded to 0.
6. I'm are not sure to understand what exactly you mean but probably you'll solve it using Color Line Tool or Color Band Tool and calculating your percentages manually.
