Using Greek characters TeeChart 7
Norcom
Post by Norcom » Fri Nov 23, 2007 10:22 am
Good morning,
Could someone please explain how can I set TeeChart7 to display Greek characters?
I have downloaded the Unicode cab/ocx but when trying to display a chart with Greek characters I either get a 'Wrond .tee file format' error, or in best case the graph without any greek characters visible.
The chart as is created as XML by the application and I'm using the XML import utility to show it. Using Internet Explorer 7 on WinXPPro SP2.
I also noticed that there is another ocx available marked as 'Multilanguage', but while in the description on the download page it says that it includes greek, there is no code given in the documentation that comes with it.
Thank you,
George
Post by Narcís » Fri Nov 23, 2007 10:32 am
Hi George,
You could try what's suggested here.
Norcom
Post by Norcom » Fri Nov 23, 2007 1:09 pm
Hi Narcis,
Thanks for replying.
Unfortunately, the way described in that thread cannot be done.
As I said, our application produces an XML file with the data, and that file is imported into a TeeChart object of an html (.asp) page, like this:
Chart = Server.CreateObject( "TeeChart.TChart" );
SeriesXMLSource = Server.CreateObject( "TeeChart.SeriesXMLSource" );
and then using the SeriesXMLSource methods.
The result is sent back as stream (Response.BinaryWrite( Chart.Export.asNative.SaveToStream( true ) );)
It's not like it's displaying question marks. It displays nothing, or produces error "Wrong .tee file format" as I already said above.
Ideas welcome...
George
PS... Here's a sample XML code that it's being sent to TeeChart:
I also trying encoding="UTF-8" without success.
The page reports error "Wrong .tee file format"
<?xml version="1.0" encoding="ISO-8859-7"?>
<chart>
<series title="Άγνωστη" type="Bar">
<points count="3">
<point text="Millennium Bank" index="0" Y="0"/>
<point text="Μαργέλης Σπύρος" index="1" Y="2"/>
<point text="Πανελλήνια Τράπεζα" index="2" Y="1"/>
</points>
</series>
<series title="Αθήνα" type="Bar">
<points count="3">
<point text="Millennium Bank" index="0" Y="1"/>
<point text="Μαργέλης Σπύρος" index="1" Y="1"/>
</points>
</series>
</chart>
Post by Narcís » Fri Nov 30, 2007 11:35 am
Hi Norcom,
It works fine for us here as shown in the example I've just sent you. Can you please test if it works fine at your end?
Norcom
Post by Norcom » Fri Jan 25, 2008 11:27 am
Hello Narcis,
I'm sorry for late reply, but I was on a long leave.
I haven't received any example. Where did you send it? Could you please send it again?
The problem still exists.
George
Post by Narcís » Fri Jan 25, 2008 3:23 pm
Hi George,
I sent the e-mail to your forums contact e-mail address. I resent it again. Have you received it now? Is the forums e-mail address correct?
Norcom
Post by Norcom » Mon Jan 28, 2008 9:15 am
Hi Narcis,
Got it now. Thanks. I see you are using a slightly different way to load the xml than the one I used.
I will try it out and see what happens.
One more question please.
Which runtime files are to be used?
Unicode? Unicode multilanguage? Multilanguage?
George
Post by Yeray » Mon Jan 28, 2008 9:39 am
Hi George,
Let me explain a little bit. While unicode version allows you to display unicode characters in a chart, multilanguage version allows you to change the language of the design-time menu. And multilanguage + unicode version does both things.
So, I think Narcis pointed you to try to use CodeUTF8String function, with unicode version (or unicode+multilanguage), to see if it works fine for you.
Norcom
Post by Norcom » Thu Feb 14, 2008 11:55 am
Hello again,
I managed to display Greek Characters on the labels, marks etc, but I'm still unable to display Greek characters at the footer text.
I used the Chart.Footer.Font.Charset property but it didn't work.
Also tried to change the font name. Similar result.
Could you please advise which property I have to change to get Greek characters displayed in the footer?
Thanks!
George
PS How do I upload a screenshot here to show what I mean?
Post by Pep » Mon Feb 18, 2008 11:59 am
Hi George,
you should be able to add Greek characters to the footter by using code like this :
TChart1.Header.Caption = TChart1.Environment.CodeUTF8String("부동산자산 ");
In your case modifying it by : tchart1.Footer.Caption = ....
