Lots and lots of bar colours
Mortong
Post by Mortong » Mon Apr 19, 2004 2:04 pm
Good afternnon
Thank y'a;; for your pervious help.
If I have say 150 bars then the colours seem to fizzle out after say 15, can I reuse the same sequence so it looks pretty as opposed to red,green, blue, cyan, orange,orange,orange,orange,orange....
Morton
D7, Teechart 7
Post by Pep » Mon Apr 19, 2004 3:13 pm
Hi Morton,
I guess the only way to change this is to change source code and recompile TC packages (if you are source code customer). Or create your
custome array of colors.
Mortong
Post by Mortong » Tue Apr 20, 2004 5:03 pm
Erm, like how please....
Post by Pep » Tue Apr 20, 2004 6:40 pm
Hi Morton,
you can define your custom Array of colors and use it like in the following code :
Const ColorP:Array[1..10] of TColor=
        ( clRed,
          clGreen,
          clYellow,
          clBlue,
          clWhite,
          clGray,
          clFuchsia,
          clTeal,
          clNavy,
          clMaroon
var i,c : integer;
c:= 0;
for i := 0 to 19 do
  if i mod 10= 0 then c:= 1
  else c:= c+1;
  Series1.AddXY(i,random(10),'',ColorP[c]);
AMS
Using Custom Palette
Post by AMS » Thu Sep 22, 2005 11:43 am
Hi Josep,
Instead of using an array of colours, would it not be better to use the custom palette method? Could you please give an exmple using TChartSeries (Bar or something) with custom palette?
Regards john.
Post by Pep » Mon Sep 26, 2005 8:19 am
Hi john,
in TeeChart v6 and above the ColorPalette is declared as
var ColorPalette:Array of TColor;
so you can simply access/change color palette without need to recompile TeeChart sources.
