ActiveX v8 samples reference v7 control
BrindleFly
Post by BrindleFly » Wed Oct 24, 2007 5:56 pm
The provided samples don't work for me. Below is a sample object tag from the sample from C:\Program Files\Steema Software\TeeChart Pro v8 ActiveX Control\Cab files\teechart8cab.html. I believe both the CLSID and version are wrong. Can someone tell me what a valid object tag for use is?
<object
id="Chart1"
width="400"
height="268"
type="application/x-oleobject"
hspace="0"
vspace="0"
classid="CLSID:FAB9B41C-87D6-474D-AB7E-F07D78F2422E"
codebase="Teechart7.cab#version=7,0,0,8">
</object>
Post by Narcís » Thu Oct 25, 2007 8:09 am
Hi BrindleFly,
I recommend you to read the Upgrading from v7.pdf document available at v8's program group.
Hope this helps!
dastrw
Post by dastrw » Thu Nov 08, 2007 2:38 am
What if we didn't upgrade from v7, but instead got v8 new?
Post by Yeray » Thu Nov 08, 2007 9:07 am
Hi dastrw,
The document that Narcís mentioned has explanations of how to upgrade the samples made for earlier versions of TeeChart to make them work well under TeeChart v8.
dastrw
Post by dastrw » Thu Nov 08, 2007 5:36 pm
Sorry I didn't mention it in my earlier post, but the v7 references that are causing me problems are the ones in the v8 help documents.
So when I try to work through the user guides and help documents I am constantly running into message boxes telling me that TeeChart can't find the v7 files and would I like to help find them myself.
Nothing in the v7 to v8 upgrade document addresses these problems.
Is there a solution?
Post by Narcís » Mon Nov 12, 2007 9:40 am
Hi dastrw,
We are currently working on solving this issue for next maintenance release. In the meantime we can send you v7 help file.
dastrw
Post by dastrw » Mon Nov 12, 2007 5:18 pm
Someone at Steema already tried to send me the v7 support files, but they got stripped out by our corporate firewall.
Please send me the support file, but change the 'zip' extension to something else like 'txt' so that the attachment won't get stripped out.
Thank you.
Post by Narcís » Tue Nov 13, 2007 10:01 am
Hi dastrw,
Sure! Just sent you the file.
