TeeChart Installation for JBuilder 2007
JT
Post by JT » Tue Sep 04, 2007 1:50 pm
I've purchased TeeChart v1 for Java and would like to add it to the palette in the visual editor of JBuilder 2007. I've tried all hints/infos that are currently available in the Java forum. Nothing worked out so far. Please give me advice.
Thanks for your time,
Joerg
tom
Post by tom » Wed Sep 05, 2007 10:57 pm
Could you tell us exactly which steps you followed trying to install teeChart for Java?
Tom.
tom
Post by tom » Sun Sep 09, 2007 6:01 pm
See also http://www.teechart.net/support/viewtopic.php?t=6556
JBuilder2007 uses Eclipse platform, so it is different from previous versions of JBuilder.
If you add the TeeChart.Swing.jar as a library, you can use the teechart widgets inside the Visual Editor, using the Choose Bean option.
To have the components appear on the palette a plugin needs to be created. For more information we refer to the eclipse documentation. Later versions of teechart might include such a plugin
tom
