Showing Series Label Below Each Pie Chart and Mark Position
Isaac Alexander
Post by Isaac Alexander » Fri Aug 03, 2007 10:50 pm
I am using D7 and Tee8.
I have 3 pie series in a single TChart which are displayed horz. I would like to have the series name below each one. Is this possible?
Also, I would like to have the pie marks show up on top of the pie slices. The reason for this is because when marks are displayed, the chart gets shrunken to a point of not being visible. I've tried playing with the mark positions, but it's not going well. Any ideas?
I posted a similar question on the newsgroup, but I noticed that this forum exists.
xxxxxx
Post by xxxxxx » Sat Aug 04, 2007 2:23 pm
Hi, Isaac Alexander!
Try to change Series Marks Callout Distance and Length properties to negative like this
      Marks.Callout.Distance = -11
      Marks.Callout.Length = -9
Seems produces desired effect.
For Legends see e.g. Multiple Legends Demo (Legend_Multi.pas) in Tee8New Demo
PS. Alexander is your name or surname?
Regards, Alexander
TeeChart Pro v8.05, Delphi 5 & Turbo Delphi Professional for Win32., Delphi & C++Builder 2009
Isaac Alexander
Post by Isaac Alexander » Tue Aug 07, 2007 7:30 pm
9047589 wrote:Try to change Series Marks Callout Distance and Length properties to negative like this
It helps with moving the mark labels on top of the pie slices, but the margins between each pie series are still huge. It changed a little with the above change. Is there a way to change the margin size that gets reserved for each series marks?
That looks like it would work for legends for each series, but I only want the name of the series below each pie. Can it be done the the BeforeDrawValues event with the custom series drawing? If so, is there an example?
Alexander is my last name. Not sure how that got into the signature. I didnt have one set. I put one it.
xxxxxx
Post by xxxxxx » Tue Aug 07, 2007 9:42 pm
Hi, Isaac!
10046043 wrote:Is there a way to change the margin size that gets reserved for each series marks?
Do you try to achieve an effect like this
Image?
If you use D7, that was shipped with TeeChart Standard, look at Demos\Teechart\udraw.pas in your Delphi. And I recommend use AfterDraw* events.[/img]
Regards, Alexander
Isaac Alexander
Post by Isaac Alexander » Tue Aug 07, 2007 11:32 pm
Image?
Not really, I'm looking for something more like this.
Current display:
What I want to display:
That example doesn't seem to show how to dump additional text on the screen.
Post by Yeray » Wed Aug 08, 2007 8:25 am
Hi Isaac,
If the Pie Series title is not going to change during execution I suggest you to use annotation tools or labels.
Otherwise, you should use the OnAfterDraw event suggested above.
xxxxxx
Post by xxxxxx » Wed Aug 08, 2007 9:00 am
10046043 wrote: Image
Obana! ("Wow" in Russian:)
Could you explain how you managed to draw pie series side by side?
Regards, Alexander
Marjan
Post by Marjan » Wed Aug 08, 2007 1:10 pm
Hi.
I think he used OnBeforeDrawValues event (as demonstrated in TeeChart "Multiple Pies" demo) with a little twist:
procedure TPieMultiple.Series1BeforeDrawValues(Sender: TObject);
  Chart1.ChartRect:=Rect(10,10,Chart1.Width div 3, Chart1.Height - 10);
procedure TPieMultiple.Series2BeforeDrawValues(Sender: TObject);
  Chart1.ChartRect:=Rect(Chart1.Width div 3, 10, 2*(Chart1.Width div 3),Chart1.Height-10);
procedure TPieMultiple.Series3BeforeDrawValues(Sender: TObject);
  Chart1.ChartRect:=Rect(2*(Chart1.Width div 3), 10,Chart1.Width, Chart1.Height-10);
As for series title below each pie, you can draw required text in the Chart OnAfterDraw values. Something like this:
var x,y,w: Integer;
  st: String;
  i,tw: Integer;
  With Chart1, Chart1.Canvas do
    y := Chart1.ChartRect.Bottom-10;
    Font.Style := [fsBold];
    // assume all series are pies in-a-row
    w := Chart1.Width div Chart1.SeriesList.Count;
    for i := 0 to Chart1.SeriesList.Count -1 do
      tw := TextWidth(Chart1.Series[i].Title);
      x := i*w + (w-tw) div 2;
      TextOut(x,y,Chart1.Series[i].Title);
And finally, to reduce the margins between pies, try setting each pie CustomXRadius and CustomYRadius properties to meaningful values. In your case, something like this:
Series1.CustomXRadius := Chart1.Width div 3 -30;
Series1.CustomYRadius := Series1.CustomXRadius;
BTW, new TeeChart v8 VCL already automatically arranges multiple pie series (in multiple rows/cols).
Marjan Slatinek,
Isaac Alexander
Post by Isaac Alexander » Wed Aug 08, 2007 6:12 pm
You are correct. I used the following code.
procedure TMyChart.CustomBeforeDrawValues(Sender: TObject);
  TempIndex, TempWidth : integer;
  TempIndex := SeriesList.IndexOf(Sender);
  TempWidth := Width div SeriesList.Count;
  ChartRect := Rect(TempWidth * TempIndex, 0, TempWidth * (TempIndex + 1), Height);
procedure TMyChart.CustomAfterDraw(Sender: TObject);
  i, TempTextWidth, TempX, TempY, TempWidth: Integer;
  with Canvas do
    TempY := ChartRect.Bottom - 15;
    for i := 0 to SeriesList.Count -1 do
      if (Series[i] is TCircledSeries) then
        TempTextWidth := TextWidth(Series[i].Title);
        TempX := (i * TempWidth) + (TempWidth - TempTextWidth) div 2;
        TextOut(TempX, TempY, Series[i].Title);
Thanks. That worked perfectly.
It's working, sort of. I would like the pies to increase in size as the chart form is resized. If I set the Custom Radiuses once, then the pies don't resize. Also, the space between pies shrink, but the space before the first pie does not. The labels for the pies move perfectly, but the pies do not.
Here's the code:
procedure TMyChart.ResizeMultipleCircledSeries;
  i, TempSize : integer;
  if (SeriesList.Count > 1) then
    for i := 0 to (SeriesList.Count - 1) do
        with (Series[i] as TCircledSeries) do
          TempSize := (Self.Width div SeriesList.Count) - 30;
          CustomXRadius := TempSize;
          CustomYRadius := CustomXRadius;
Here is the small view (400 x 140)
Here is the larger view (795 x 138)
If I put the code in the Resize event of the chart, I can't seem to get the calc working correctly. The pies keep growing at a faster rate than the form which cause them to grow outside the margins of the chart.
I saw this. Doesn't it automatically make them two deep? I would like to control the number of pies per row.
Post by Narcís » Thu Aug 09, 2007 9:58 am
Hi Isaac,
Maybe you could solve this much easily. You could align the chart to the form:
  Chart1.Align:=alClient;
Or use something like the code below in the form's OnResize event:
  tmpWidth:=Width;
  tmpHeight:=Height;
procedure TForm1.FormResize(Sender: TObject);
  Chart1.Width:=Chart1.Width+(Width-tmpWidth);
  Chart1.Height:=Chart1.Height+(Height-tmpHeight);
  tmpWidth:=Width;
  tmpHeight:=Height;
Isaac Alexander
Post by Isaac Alexander » Thu Aug 09, 2007 3:25 pm
I wish it were that simple. I want to show pies in a different orientation than the default which causes me to set the series Rects myself. The chart is aligned to the form/panel. If the panel could not be resized, I would be done. The problem is that with the resizing. I can't get it to scale properly. The pies grow faster than the form/panel. Please see my earlier comments. Thanks.
Post by Narcís » Tue Aug 14, 2007 1:38 pm
Hi Isaac,
Using what Marjan suggested and aligning the chart to alClient automatically resizes the pies when re-dimensioning the form. Have you tried using something like this?
  Series1.MultiPie:=mpDisabled;
  Series2.MultiPie:=mpDisabled;
  Series3.MultiPie:=mpDisabled;
  Series1.Circled:=true;
  Series2.Circled:=true;
  Series3.Circled:=true;
  Series1.FillSampleValues();
  Series2.FillSampleValues();
  Series3.FillSampleValues();
procedure TForm1.Series1BeforeDrawValues(Sender: TObject);
  Chart1.ChartRect:=Rect(10,10,Chart1.Width div 3, Chart1.Height);
procedure TForm1.Series2BeforeDrawValues(Sender: TObject);
  Chart1.ChartRect:=Rect(Chart1.Width div 3,10, (Chart1.Width div 3)*2, Chart1.Height);
procedure TForm1.Series3BeforeDrawValues(Sender: TObject);
  Chart1.ChartRect:=Rect((Chart1.Width div 3)*2, 10, Chart1.Width, Chart1.Height);
If the problem persists, could you please send us a simple example project we can run "as-is" to reproduce the problem here?
You can either post your files at news://www.steema.net/steema.public.attachments or at our upload page.
