In Line graphs, default Pattern for Point is white, which is
ESRI
Post by ESRI » Thu Jul 12, 2007 3:29 am
Hi.
For a Line series graph, the default Pattern for the Point tab seems to use the None colour, so that the entries in the drop-down list (other than the selected one) from the Style button all appear blank. They in fact are white, but are therefore not visible with the default display.
Is it possible to have this behaviour change so that the default colour is black?
Juan
Post by Pep » Thu Jul 12, 2007 8:58 am
Hi Juan,
I'm sorry, I cannot reproduce the problem here, I tried with the following steps (all at design time) :
- Add a TChart, edit and add a TLineSeries
- Go to "Point" tab of the "Series0", visible is set to "False", so pattern cannot be edited.
- Check the "Visible" option, click then the "Pattern" button.
- the default Style is "Solid" and default color is "Black".
Could you plesae tell me all the steps I must do in order to reproduce it here ?
Also, which TeeChart Pro version are you using ?
