Problems with IE7
Nova
Problems with IE7
Post by Nova » Fri Jul 06, 2007 8:31 pm
I implement TeeChart version 6, and also try the new version 7.0.1.4, in an ASP page but when I try it in IE7 on Windows XP in some PC it doesn't work propoly, the grafic appears but the data isn't right.
In oders computers with Windows 2000 and IE6 and even in oder Windows XP with IE7 it works fine. I don't know were the problem could be. There are any knowing problem that could happen only in some cases? Or some configurations should be set up before?
Tks
Post by Pep » Mon Jul 09, 2007 8:47 am
Hi Nova,
most likely the problem could be related with the permissions of the folder where you have the asp files. Are you able to run asp files (which do not contain Charts) placed on the same folder ?
Nova
Post by Nova » Tue Jul 10, 2007 1:12 pm
Hi Pep,
Yeah, all other pages of my website works fine, all they with asp codes.
The problems seems to be with some machines, like I said before, in some computers all pages works.
And another thing that I notice is the grafic don't show the points load from my SQL data base, other points that still depend of my data base but are constant are displayed.
There are any configuration that I have to set up on the client PC to all works?
Tks
Nova
Post by Nova » Tue Jul 10, 2007 2:20 pm
I found the problem. It's the format of date in the computer is not in same language of Internet Explore. I just don't know how to solve it, yet.
I have another problem only in TeeChart v7. How to set up the color of the line, because when I use:
- TChart1.Series(0).AddXY DateValue("1/1/1999") + TimeValue("11:59:00"), 45, "", RGB(255,0,0)
or
- TChart1.Series(2).asLine.LinePen.Color = vbBlue
They only set the points color not line color. And works in v6.
tks
Post by Yeray » Wed Jul 11, 2007 8:56 am
Hi Nova,
We are happy to see that you've found the first problem.
Your second problem appears because you add your values assigning a color to each point so the series is set to ColorEachPoint=true. And then, assigning a color to your series doesn't affect to the points.
Otherwise you should assign the color clTeeColor and then your series response will be as you wish, we think.
