TVolumeSeries color
quickweb
TVolumeSeries color
Post by quickweb » Fri Jul 06, 2007 2:47 pm
hello,
I have the following step programs:
1. savechart (initial chart) to strem;
2. load chart from stream in another chart;
3. change chart properties: series color, chart background....
When I change TVolumeSeries color, the new color is applyed in chart.
After these I want to apply the new properties to initial chart.
4. clik one button for this.
The TVolumeSeries color remain unchanged on a grafic, even in chart editor I can see the new color.
Could you help?
Thank you,
Cristina
Post by Narcís » Fri Jul 06, 2007 8:03 pm
Hi Cristina,
Could you please send us a simple example project we can run "as-is" to reproduce the problem here?
quickweb
TVolumeSeries color
Post by quickweb » Mon Jul 09, 2007 3:56 pm
I have uploaded a demo to the upload server.
This demo reproduces the bug:
- open up a chart, edit the properties by altering the volume series color
- apply that property; you will notice the chart volume series is not altered
- add some more points to the series. The effect is that the new points are added with the new color, while the series points already there are kept with the old color.
Cristina
Post by Yeray » Tue Jul 10, 2007 11:06 am
Hi Cristina,
We noticed that in your volume series you add your values with a color for each point, and since then, changing the series color doesn't affect to the points.
So you could add your points using teecolor instead of volumeSeries->Color
tmp =  volumeSeries->AddXY(i,random(20),"", clTeeColor);
//                volumeSeries->Color);
Or you could assign the new color for each point with a for.
quickweb
Post by quickweb » Tue Jul 10, 2007 11:58 am
It works. Thank you.
Cristina
quickweb
Post by quickweb » Tue Jul 10, 2007 12:19 pm
Also, I don't know what I am doing wrong with settings for bollinger function properties because the LowBand color is not updated.
I create a function with default properties, and after that assign new properties:
// set Bollinger function properties
TLineSeries* fSeries = indicatorObject->series;
TBollingerFunction* f = (TBollingerFunction*)fSeries->FunctionType;
fSeries->SeriesColor = indicatorObject->color;
fSeries->Pen->Style = indicatorObject->style;
fSeries->Pen->Width = indicatorObject->width;
fSeries->YValues->ValueSource = indicatorObject->getParamsByName("Apply to")->value;
f->Period = StrToInt(indicatorObject->getParamsByName("Period")->value);
fSeries->FunctionType->Period = f->Period;
f->Deviation = StrToInt(indicatorObject->getParamsByName("Deviation")->value);
f->Exponential = StrToBool(indicatorObject->getParamsByName("Exponential")->value);
f->LowBandPen->Color = StringToColor(indicatorObject->getParamsByName("LowBandColor")->value);
f->LowBand->SeriesColor = f->LowBandPen->Color;
f->LowBandPen->Style = indicatorObject->style;
fSeries->CheckDataSource();
Thanks for your help,
Cristina
Post by Narcís » Mon Jul 30, 2007 9:59 am
Hi Cristina,
Have you managed to solve the problem? If not, could you please send us a simple example project we can run "as-is" to reproduce the problem here?
Post by Narcís » Mon Jul 30, 2007 10:03 am
Hi Cristina,
Ok, now I found this has continued here.
