Resizing chart by dragging
nbp
Post by nbp » Wed Jun 20, 2007 6:15 pm
I have a TChart on a PropertyPage. I want to add the capability to resize the chart by clicking on the corners (or border) of the chart panel and then dragging the corner (or border) to resize the panel. Is there an example that I can use?
Post by Pep » Fri Jun 22, 2007 4:35 pm
what about using the Selector Tool, setting the AllowResize to true ?
tchart1.Tools.Items(0).asSelector.AllowResizeChart = True
ModelTech
Post by ModelTech » Thu Nov 22, 2007 2:32 pm
I have tried to "translate" suggested solution for VBScript. Unfortunately, it does not work.
Is it possible to modify this code into VBScript for using with IE7?
Thanks in advance,
Danila.
Post by Pep » Mon Nov 26, 2007 11:59 am
Hi Danila,
to change the size of the ActiveX object with vbScript you will have to use the standard ms techniques, like :
Sub Window_Onload()
    Set obj = document.all("TChart1")
    obj.style.pixelWidth = screen.width
    obj.style.pixelHeight = screen.height
    FillChart()
