Activex DNS chartload problems
David
Post by David » Tue Mar 30, 2004 5:34 pm
I'm am using TeeChart ActiveX v5 in MS 2003 ASP.Net. When a user calls the webpage using the computer name (i.e. //w14700) all works fine. When a user calls the page using a DNS name (i.e. ops_support) the page no longer works. Part of the problem may be in the way I am attempting to make all the calls relative to the machine it is loaded on. However, I did try hard coding the address even using the DNS and it did not work. Here's a code snippet:
if right(webform1.document.url,1)="/" then
servername=webform1.document.url
servername= left(webform1.document.url,len(webform1.document.url)-13)
end if
TChart1.Import.LoadFromURL(servername + "WebForm2.aspx")
TChart2.Import.LoadFromURL(servername + "WebForm3.aspx")
Post by Pep » Thu Apr 01, 2004 9:48 am
Hi David,
is it a problem specific to TChart ? Can you load an image into a picture box using your DNS server names (for example)?
David
Post by David » Thu Apr 01, 2004 8:11 pm
The page has other information on it which loads fine using the DNS. I don't even get an error from TChart (I was for a while, but when I registered the DNS name in IIS on the machine, that went away, but still no chart displayed).
Post by Pep » Mon Apr 05, 2004 5:08 pm
Hi David,
have you check the IIS permissions ?
