TeeChart and SWT
to2
TeeChart and SWT
Post by to2 » Tue May 08, 2007 3:42 pm
For our Java project we decided to use SWT for the GUI. I wonder if TeeChart can be used as a SWT component?
Best Regards
Thomas
Post by Narcís » Wed May 09, 2007 8:43 am
Hi Thomas,
TeeChart for Java includes a component for SWT and a Swing one. I'd recommend you to download the fully functional evaluation version to check if TeeChart for Java fits your needs.
Evaluation version can be downloaded here.
to2
Post by to2 » Wed May 09, 2007 10:23 am
narcis wrote:I'd recommend you to download the fully functional evaluation version to check if TeeChart for Java fits your needs.
We downloaded the eval version and inserted it as project in Eclipse. Do you have a install guide for installing in Eclipse? Can TeeChart be included to the component palette of Visual Editor? If not, how can I access properties in design time?
Best Regards
Thomas
Post by Narcís » Wed May 09, 2007 11:28 am
Hi Thomas,
You need to use TeeChart.Swing.jar as in the example here.
