TColorLineTool glitch
fabnav
Post by fabnav » Tue May 08, 2007 3:28 am
I'm trying to use the TColorLineTool to draw horizontal lines at the bottom and top of the left axes.
It works, except in the case of a bar chart with visible marks. Bar charts with marks automatically rescale in order to fit the marks on the chart. I don't know why only bar charts do this. Other chart series types don't, though it might be nice if they did.
In any case, when the marks are visible, the color line with a style of clMaximum, isn't positioned at the top of the axis, but at the top of the bar.
I have included a simple unit that shows this. I would appreciate help in getting the line to always be positioned at the top of the axis, regardless of the series type, or marks visibility. Maybe there is some other way to do it.
Bill
unit Unit1;
interface
uses
Dialogs, TeEngine, Series, ExtCtrls, TeeProcs, Chart, StdCtrls;
type
TForm1 = class(TForm)
Chart1: TChart;
Series1: TBarSeries;
CheckBox1: TCheckBox;
procedure CheckBox1Click(Sender: TObject);
private
{ Private declarations }
public
{ Public declarations }
Form1: TForm1;
implementation
{$R *.dfm}
uses
TeeTools;
procedure TForm1.CheckBox1Click(Sender: TObject);
Series1.Marks.Visible := CheckBox1.Checked;
I: Integer;
ColorLineTool: TColorLineTool;
for I := 0 to 10 do
Series1.Add(I, IntToStr(I));
{ Maximum line }
ColorLineTool := Chart1.Tools.Add(TColorLineTool.Create(Self)) as TColorLineTool;
ColorLineTool.Axis := Chart1.LeftAxis;
ColorLineTool.Style := clMaximum;
end.
object Form1: TForm1
Left = 0
Top = 0
Caption = 'Form1'
ClientHeight = 407
ClientWidth = 617
Color = clBtnFace
Font.Charset = DEFAULT_CHARSET
Font.Color = clWindowText
Font.Height = -11
Font.Name = 'Tahoma'
Font.Style = []
OldCreateOrder = False
OnCreate = FormCreate
PixelsPerInch = 96
TextHeight = 13
object Chart1: TChart
Left = 49
Top = 43
Width = 400
Height = 250
Title.Text.Strings = (
'TChart')
TabOrder = 0
object Series1: TBarSeries
Marks.Callout.Brush.Color = clBlack
Marks.Visible = True
Gradient.Direction = gdTopBottom
XValues.Name = 'X'
XValues.Order = loAscending
YValues.Name = 'Bar'
YValues.Order = loNone
end
end
object CheckBox1: TCheckBox
Left = 23
Top = 10
Width = 97
Height = 17
Caption = 'CheckBox1'
TabOrder = 1
OnClick = CheckBox1Click
end
end
Post by Yeray » Tue May 08, 2007 10:30 am
Hi Bill,
The problem is that when you have your axis maximum set to auto (Chart1.Axes.Left.AutomaticMaximum is true) the ChartRect is recalculated to fit the marks (if they're visible) but Chart1.Axes.Left.Maximum is not changed. So to draw your line at the top of the ChartRect you should replace this line:
for this anotherone:
ColorLineTool.Value := Chart1.Axes.Left.CalcPosPoint(Chart1.Axes.Left.IStartPos);
fabnav
Post by fabnav » Tue May 08, 2007 12:32 pm
I tried what you suggested but got the same result. I included my modified code below. Note: I moved the creation of the lines into the AfterDraw event. I also gave the top and bottom lines different colors to make it easier to see what is happening. With this code, the lines aren't right when I zoom either.
unit Unit1;
interface
uses
type
Chart1: TChart;
Series2: TPointSeries;
procedure Chart1AfterDraw(Sender: TObject);
private
public
Form1: TForm1;
implementation
{$R *.dfm}
uses
TeeTools;
AAxes: Integer;
Chart1.Tools.Clear;
for AAxes := 0 to Pred(Chart1.AxesList.Count) do
if (Chart1.AxesList.Items[AAxes].Title.Caption = 'Left 1') or
(Chart1.AxesList.Items[AAxes].Title.Caption = 'Custom 1') then
{ Minimum line }
ColorLineTool.Axis := Chart1.AxesList.Items[AAxes];
ColorLineTool.Style := clMinimum;
ColorLineTool.Pen.Color := clGreen;
ColorLineTool.Pen.Width := 2;
{ Maximum line }
ColorLineTool.Value := ColorLineTool.Axis.CalcPosPoint(ColorLineTool.Axis.IStartPos);
ColorLineTool.Pen.Color := clRed;
I: Integer;
for I := 0 to 10 do
Series2.Add(I, IntToStr(I));
Chart1.Draw;
end.
Post by Yeray » Wed May 09, 2007 8:12 am
Hi Bill,
I'm sorry but I'm not sure to understand what exactly you need. Why have you moved the Lines creation to OnAfterDraw event? You want to have always a line at the top of the chart and anotherone at the bottom?
I've modified your new OnAfterDraw event to achieve it and it remains:
AAxes: Integer;
  Chart1.Tools.Clear;
    if (Chart1.AxesList.Items[AAxes].Title.Caption = 'Custom 1') then
      { Minimum line }
    end
    else if (Chart1.AxesList.Items[AAxes].Title.Caption = 'Left 1') then
      { Maximum line }
      ColorLineTool.Value := Chart1.AxesList.Items[AAxes].IEndPos;
And the form:
  Left = 189
  Top = 86
  Width = 641
  Height = 434
  Caption = 'Form1'
  Color = clBtnFace
  Font.Height = -11
  Font.Style = []
  PixelsPerInch = 96
  TextHeight = 13
    Left = 49
    Top = 43
    Width = 512
    Height = 310
      'TChart')
    BottomAxis.Axis.Width = 1
    CustomAxes = <
      item
        Horizontal = False
        OtherSide = True
      end>
    LeftAxis.Axis.Width = 1
    LeftAxis.Title.Caption = 'Left 1'
    View3D = False
    OnAfterDraw = Chart1AfterDraw
    TabOrder = 0
      Marks.Arrow.Visible = True
      Marks.Callout.Arrow.Visible = True
      VertAxis = aCustomVertAxis
      XValues.Name = 'X'
      CustomVertAxis = 0
    end
    object Series2: TPointSeries
      Marks.Visible = False
      ClickableLine = False
      Pointer.InflateMargins = True
      Pointer.Style = psRectangle
      Pointer.Visible = True
      XValues.Name = 'X'
      YValues.Name = 'Y'
    end
  end
    Left = 23
    Top = 10
    Width = 97
    Height = 17
    TabOrder = 1
  end
end
fabnav
Post by fabnav » Wed May 09, 2007 12:27 pm
When you have multiple axes, one above the other, and in my application I allow up to four, it looks better when there is something to clearly mark where one axis ends and the next starts. I am trying to draw a thick line at the bottom and the top of each axis to achieve this effect. It should look as if I have multiple charts stacked one above the other.
It would look even better if I could place a shape (filled rectangle) between the axes, but I'm not sure how to do that.
Bill
Post by Yeray » Fri May 11, 2007 8:42 am
Hi Bill,
I achieved what you requested working with:
-StartPosition and EndPosition percents from Custom axes.
-Chart1.CustomAxes.Items.CalcPosPoint(Chart1.CustomAxes.Items.IEndPos) and IStartPos pixels from Custom Axes.
-Value pixels from Color Line Tools.
-Left, Width, Top, Height pixels from Rectangle Tools.
The following code shows you a complete example. I only added a chart, a combobox and a checkbox in designtime to show everything by code:
const nSeries = 4;
var i: Integer;
  Chart1.View3D := false;
  Chart1.Title.Visible := false;
  Chart1.Legend.Visible := false;
  Chart1.MarginLeft := 5;
  Chart1.Axes.Bottom.Axis.Width := 1;
  for i:=0 to nSeries-1 do
    Chart1.AddSeries(TLineSeries);
    ComboBox1.Items.Add('Series' + inttostr(i+1));
    With Chart1.CustomAxes do
      Add;
      Chart1.Tools.Add(TColorLineTool);
      (Chart1.Tools.Items[i*2] as TColorLineTool).Axis := Items[i];
      (Chart1.Tools.Items[(i*2)+1] as TColorLineTool).Axis := Items[i];
      Chart1[i].CustomVertAxis := Items[i];
      Items[i].PositionUnits := muPixels;
      Items[i].Axis.Width := 1;
      Items[i].Axis.Color := Chart1[i].Color;
    Chart1[i].FillSampleValues();
  for i:=0 to Chart1.SeriesCount-2 do
    Chart1.Tools.Add(TRectangleTool);
    (Chart1.Tools.Items[i+Chart1.SeriesCount*2] as TRectangleTool).PositionUnits := muPixels;
  ComboBox1.ItemIndex := 0;
  Chart1.Draw;
  CalcPositions;
  for i:=0 to (Chart1.SeriesCount*2)-1 do
    ((Chart1.Tools.Items[i]) as TColorLineTool).AllowDrag := false;
procedure TForm1.ComboBox1Change(Sender: TObject);
  CheckBox1.Checked := Chart1[ComboBox1.ItemIndex].Marks.Visible;
  Chart1[ComboBox1.ItemIndex].Marks.Visible := CheckBox1.Checked;
  Chart1.Draw;
  CalcPositions;
procedure TForm1.CalcPositions;
var percent, i: Integer;
  percent := 100 div Chart1.SeriesCount;
  for i := 0 to Chart1.CustomAxes.Count-1 do
      Items[i].StartPosition := (percent * i) + percent/5;
      Items[i].EndPosition := (percent * (i+1)) - percent/5;
      ((Chart1.Tools.Items[(i*2)+1]) as TColorLineTool).Value := Items[i].CalcPosPoint(Items[i].IEndPos);
      ((Chart1.Tools.Items[i*2]) as TColorLineTool).Value := Items[i].CalcPosPoint(Items[i].IStartPos);
  Chart1.Draw;
  for i := (Chart1.SeriesCount*2) to (Chart1.SeriesCount*2 + Chart1.SeriesCount-2) do
    With (Chart1.Tools.Items[i] as TRectangleTool), Chart1.CustomAxes do
      Left := Chart1.ChartRect.Left;
      Width := Chart1.ChartRect.Right-Chart1.ChartRect.Left+2;
      Top := Items[i-(Chart1.SeriesCount*2)].IEndPos;
      Height := Items[i-(Chart1.SeriesCount*2)+1].IStartPos - Items[i-(Chart1.SeriesCount*2)].IEndPos + 2;
      AllowDrag := false;
      AllowResize := false;
fabnav
Post by fabnav » Mon May 14, 2007 1:30 pm
I went with drawing rectangles between the axes in the AfterDraw event handler. What I needed to know, was where to place them, and I got that from looking at your code (IStartPos and IEndPos).
Bill
