TCursortool.Yvalue
Heiko
TCursortool.Yvalue
Post by Heiko » Sat Apr 28, 2007 9:09 am
I can read out the vertical position of a horizontal Cursortool by
TCursortool.YValue
in scales of the axis.
But which axis does this refer to if I have more then one?
In my example I normally have a left and a right vertical axis and I want to read out both YValues of my horizontal Cursor tool.
How can I do this?
Greetings,
Heiko
Post by Yeray » Mon Apr 30, 2007 8:14 am
Hi Heiko,
Here's an example of how you can show Y values from both left and right axis using OnMouse event instead of Cursor Tool.
  Y: Integer);
  Chart1.Title.Caption := 'LeftAxis Y: ' + floattostr(Chart1.Axes.Left.CalcPosPoint(Y)) + '  RightAxis Y: ' + floattostr(Chart1.Axes.Right.CalcPosPoint(Y));
Heiko
Difference between two CursorTools
Post by Heiko » Sat May 12, 2007 8:14 am
Thanks for the answer. But I think this doesn't help me?
I want (as an example) to get the difference between two horizontal CursorTools. Both in measures of the left and right axis.
This, whenever I move one of the two CursorTools.
For the left axis this is no problem:
CursorTool.YValue
But what do I have to do with my right axis?
Heiko
Post by Yeray » Mon May 14, 2007 9:31 am
If you want the difference between the YValues from Cursor Tools associated to different series (associated to different axes) you can simply calculate it but that'll be a difference between values from different scales.
You can also calculate the YValue of a cursor tool for another axis (not associated) like this:
Chart1.Title.Caption := 'RightAxis Y: ' + floattostr(Chart1.Axes.Right.CalcPosPoint(Chart1.Axes.Left.CalcYPosValue(Cursor1.YValue)));
