problem with CursorTool after export
nitin
Post by nitin » Fri Apr 13, 2007 9:47 am
hello,
the problem is when i use cursor tool, after export to pdf cursor behave abnormall like brush. I have put on newsgrup zip with files to show problem.
thanks in advance
Post by Yeray » Fri Apr 13, 2007 10:30 am
Hi guzial,
Take a look at this post where there's a discussion about the same problem.
nitin
Post by nitin » Mon Apr 16, 2007 7:49 am
my problem is different, i have send on newsgroup please write what to do
Post by Yeray » Mon Apr 16, 2007 8:57 am
Hi guzial,
sorry for the bad link to post. The issue you requested is discussed in that other one.
nitin
Post by nitin » Mon Apr 16, 2007 12:03 pm
ok so can you write me deadline for new release? Now we can't use Teechart as want to. CursorToll doesn't work proper after export to PDF format and we can't to resign from export to pdf format which has bugs for us
http://www.teechart.net/support/viewtop ... 91bc4333df
everthing what we should to do in our application the solution for us was to buy TeeChart Pro and now everthing has some small bugs what makes that we are in the same point which mean that we can't do anything.
so when can we expect for no bugs in export to pdf and cursorTool ??
Post by Yeray » Tue Apr 17, 2007 7:41 am
Hi guzial,
We're working on a solution for the pdf issue. But we cannot give you a date for a fix yet.
Regarding the cursor tool issue you mentioned at the thread above, we aren't able to reproduce your problem. That's why we asked for an example.
