Hi!
I'm using ReportBuilder + TeeChart Pro 7.0 (TDBChart)
I have a table with 3 fields : ID, ValueX, ValueY
I want to plot a standard point graphic using ValueX and ValueY as axis values, but I need to display the value of the ID field in the chart legend. I tried to set ID as the LABEL, but it mess the X axis scale. I can have more than one record with the same value for X and Y.
Now I'm trying to use the GetLegendText event, but I could not find a way to know what record in the dataset is being processed when the event is fired and so I cannot get the right ID value to set the legend text.
Any help?
CustomLegend problem!
- Newbie
Hi Carlos,
dbchart1.Axes.Bottom.LabelStyle := talValue;
dbchart1.Legend.TextStyle := ltsPlain;
In that case if you have set the ID as a LABEL, the bottom axis will show the XValues and the Legend will show the point Label only.
Setting the Bottom Axis labels to Value should do the trick :I tried to set ID as the LABEL, but it mess the X axis scale. I can have more than one record with the same value for X and Y.
Pep Jorge
http://support.steema.com
