Change default export dialog values
myghetto
Post by myghetto » Thu Jan 11, 2007 1:26 am
Is it possible to change the default export dialog values such as the width and height values in the picture section?
Post by Narcís » Thu Jan 11, 2007 10:20 am
Hi myghetto,
To change this you need a TeeChart Pro v7 VCL with source code license and modify the default values in the editor dialogs.
myghetto
Post by myghetto » Fri Jan 12, 2007 6:10 am
I have the full source code version. I have found the TeeExport.pas and looked through the file. I am a beginner in Delphi therefore have no idea what is going on. Please guide me through how to change it. Thank you very much.
Best regards,
David
Post by Pep » Mon Jan 15, 2007 10:45 am
Hi David,
you will have to modify the form where the preview is displayed, for example you can edit the TeeBmpOptions unit, and modify as you own. Once you've form as desired you will have to recompile/install the TeeChart Pro sources in order to show changes at design time.
