Pie charts on wide screen format screens are displayed as ellipses for certain screen resolution even when I use the property (.asPie.Circled = True). For example 800x600 = "pie ok"; 1024x600 = "elliptical pie"; 1024x768 = "pie ok"; 1280x768 = "elliptical pie".
I can send screenshots if needed.
Thanks for your help.
Using TeeChart Pro v6.0.0.5
Aspect Ratios of Pie charts on wide format monitors
I have now tested the problem on other wide format monitors and the result is the same, the pie chart does not appear as a circle, it is elliptical. For example the Dell 24 inch (2407WFP) Monitor, HP Notebook Pavilion zd7000 and Sony Vaio PCG-TR5MP. Would you like me to send some screen shots? Have you been able to reproduce the problem in-house?
Dear psc,
This is not currently supported as Circled property seems not to consider the screen resolution ratio to draw itself properly. We have added your request to our wish-list to be considered for inclusion in future releases.
In the meantime, the only way I can think of is manually setting pie's XRadius and YRadius (TChart1.Series(0).asPie.XRadius and TChart1.Series(0).asPie.YRadius) properties according to the screen resolution.
Hi psc,
You can modify pie radius using something like the code below and then apply screen resolution as told in one of those pages:
http://www.freevbcode.com/ShowCode.asp? ... NoBox=True
http://www.newton.dep.anl.gov/askasci/comp99/CS029.htm
Private Sub Form_Load()
TChart1.Series(0).FillSampleValues 5
TChart1.Series(0).asPie.Circled = False
Private Sub Form_Resize()
Me.TChart1.Width = Me.Width
Me.TChart1.Height = Me.Height
With TChart1.Series(0).asPie
If .XRadius < .YRadius Then
.YRadius = .XRadius
Else
.XRadius = .YRadius
End If
End With
Hi Narcis,
That example does not work. It seems every time you set the radius in the event the chart seems to draw itself again as an ellipsce and resets the radius resulting in the chart getting smaller and smaller till it dissapears. The behaviour on a "non wide screen monitor" is fine and the pie only dissappears on a wide format monitor.
Hi psc,
That's why you should add support for wide screen resolution here as shown in one of the websites I posted.
