TeeChart 7 VCL and nulls
betterbyte
Post by betterbyte » Sat Mar 06, 2004 11:27 pm
Can you please tell me if Teechart 7 VCL for Delphi Pro 6 displays values that are null as zeros in the charts, or has this been fixed?
pl
Marjan
Post by Marjan » Mon Mar 08, 2004 9:54 pm
Hi.
I'm affraid not as you'd like it <gg>. The values are ommited, but internally they are still treated as normal points with color set to clNone. One problem which migt arise is the automatic axis range might be wrong if null points are in series. For this case, the following workaround can be used:
procedure NoNullsMinMax(Series: TChartSeries);
var i: Integer;
  aminx, amaxx: double;
  aminy, amaxy: double;
  aminx := Series.MaxXValue;
  amaxx := Series.MinXValue;
  aminy := Series.MaxYValue;
  amaxy := Series.MinYValue;
  for i := 0 to Series.Count -1 do
    if Not (Series.IsNull(i)) then
      if Series.XValue[i] < aminx then aminx := Series.XValue[i];
      if Series.XValue[i] > amaxx then amaxx := Series.XValue[i];
      if Series.YValue[i] < aminy then aminy := Series.YValue[i];
      if Series.YValue[i] > amaxy then amaxy := Series.YValue[i];
  Series.GetHorizAxis.SetMinMax(aminx,amaxx);
  Series.GetVertAxis.SetMinMax(aminy,amaxy);
  Series1.Add(10);
  Series1.Add(3);
  Series1.AddNull;
  Series1.Add(5);
  Series1.Add(7);
  NoNullsMinMax(Series1);
Hopefully we'll be able to implement something similar in next maintenance release.
Marjan Slatinek,
