Hi all
Is there a way to draw alternating color bands in the canvas, automatically? (without adding 10 or 15 or 20 band tools)
See the following for example:
http://www.omnifinance.gr/stock.asp?sym ... mode=chart
Hi norad,
this can be done with the Grid Band tool, which is available in the TeeChart Pro AX v6.
Pep Jorge
http://support.steema.com
I have used the follwing code so as to have 2 different colors on my grid...
With Chart
.Tools.Add tcGridBand
With .Tools.Items(0).asGridBand
.Axis = Chart.Axis.Left
.Band1.Color = vbGreen
.Band2.Color = vbBlue
End With
End With
But it does not seem to work. Am i forgeting something?
The page in which the above is running produces the following error
Active Server Pages error 'ASP 0115'
Unexpected error
/charts/DAILY.asp
A trappable error (C0000005) occurred in an external object. The script cannot continue running.
Any help would be much appreciated
With Chart
End With
End With
Unexpected error
/charts/DAILY.asp
Hi norad,
yes, you're correct, I get the same results using it in one ASP page. It seems to be a bug. I've added it on our defect list and a fix for it will be considered to inclusion for the next maintenance release. I've not found any workaround, if I find it I'll let you know.
Pep Jorge
