Why is addobject lacking?
achristouio
Post by achristouio » Sun Sep 17, 2006 7:37 pm
I thouhgt to use tTree instead of tTreeView in order to draw some trees where I also need to hook up some objects on the tip of each branch.
But, sorry, I cannot find any addobject method, except for the addrootobject.
Are there any plan to also connect objects to other nodes than just the root node ??
tom
Post by tom » Thu Sep 21, 2006 7:36 pm
You can use the following methods at "node" level:
AddChildObject
AddConnectionObject
You can also access it through the Data property
Tom
